Sorry Bernhardt, i can not understand this.
Here is the whole sample of the formula creat chart:
rangeStr = "A2:A" + (totsize(data)/2+1);
set range = sheet.Range(rangeStr);
set chart = sheet.ChartObjects.Add(100,100,width,height);
sheet.ChartObjects(1).Activate;
book.ActiveChart.ChartType=xlColumnStacked;
book.ActiveChart.SetSourceData(range, xlColumns);
str = "=Sheet1!R2C2:R" + (totsize(data)+1) + "C2";
//"=Tabelle1!Z2S2:Z" + (totsize(data)+1) + "S2" ; <---- your code
//book.ActiveChart.SeriesCollection(1).XValues = str; <---- original one
book.ActiveChart.HasLegend = asVariantBool(0);
book.ActiveChart.Export(filename, "jpg");
If i use your hint, then the line before would be not necessary. And there
is a difference in x=a and a=x , or not ?
What is the purpose of .XValues ?? Can not find it in my object
browser......
And Greg, with your VXL program- are there also any problems with different
language prefs of Excel ?
Thanks a lot for your inputs,
detlef
Von: Markus Bernhardt [mailto:Bernhardt@somatec.de]
Gesendet: 15 April 2004 09:35
An: 'Baranski, Detlef'; VEE Usergroup (E-Mail)
Betreff: AW: [vrf] RE: [vrf]:Excel XValue Problem
Hello Detlef,
for german EXCEL the formula for the Xvalues has to be:
str = "=Tabelle1!Z2S2:Z" + (totsize(data)+1) + "S2";
This works.
Best regards
M. Bernhardt
SOMATEC - Software fr Maschinensteuerungen
und Automatisierungstechnik GbR
Jagdweg 7a
D-82041 Deisenhofen
Telefon : (089) 613 984 94
Fax : (089) 613 981 23
Email : Bernhardt@somatec.de
homepage : www.somatec.com
This message and any attachments are confidential, for the exclusive use of
the addressee and may be legally privileged. Any other distribution, use or
reproduction is unauthorised and prohibited. If you have received this
message in error, please notify the sender immediately and delete the
message from your system.
Visit our internet site at http://www.pilkington.com
browser......
detlef
Hello Detlef,
This works.
Best regards
M. Bernhardt
Jagdweg 7a
D-82041 Deisenhofen
> automisation can be found at: www.my-vee.de/zips/autohilfe.zip
Wow! Great file Detlef. Thanks.
Is that your VEE site? I like the part about "no cookies, no jscript, no
frames"
decent job though.
Say I have one little gripe with the text of the help file. When discussing
binding, it says that late binding is declaring an object of specific class.
This is a typo. Late binding occurs when you declare an object of
*inspecific* class, then assign a specific object to it.
-SHAWN-
