vrf To compare using Array
Question asked by VRFuser on Apr 7, 2004
Hi Lyle! Hi vrf,
So I did some tests, Win2K SP5, lots of apps running, VEE revs 6.01, 6.2 and 7.0, with your app. Ran 5 times in each rev, not starting or stopping any other apps between runs, no mouse movement, logging total time as reported in the top alpha display in your app. I don't have 5.01 installed.
Got out Excel and got the following results with 95% confidence level (Excel's CONFIDENCE function) for times:
6.01: mean 2.845 seconds, expected range 2.817 to 2.874 seconds
6.2:  mean 2.973 seconds, expected range 2.905 to 3.042 seconds
7.0:  mean 3.525 seconds, expected range 3.497 to 3.553 seconds
So I'd have to say there is very likely a small but statistically significant slowdown from 6.01 to 6.2 of about 0.13 seconds (5%), probably no more than about 0.23 seconds (8%), and a much larger one from 6.2 to 7.0 of about 0.55 seconds (19%), no more than about 0.65 (22%) seconds.
If I got my stats computations right, that is. 5 may not really be enough samples and I may have had a too-long day.
I don't know what might have caused the slowdowns; nothing obvious to the eye in the 6.2 to 7.0 change list. Might need to break pieces off the program and redo comparisons till you find what the big slowdowns are, because it may not all be due to file IO time.
Best Regards,
Scott Bayes
Software Technical Support
Agilent Technologies, Inc.
815 14th Street S.W.
Loveland, CO, U.S.A. 80537
970 679 3799 Tel
970 635 6867 Fax
> -----Original Message-----
> From: Carnahan, Lyle [mailto:carnahal@tycoelectronics.com]
> Sent: Wednesday, April 07, 2004 3:34 PM
> To: PDL-LISTS,VRF (A-Lists,unix1)
> Subject: [vrf] File I/O Timing
> Hi all,
> I was just wondering if anyone has noticed slower file access
> times in VEE
> 7. I have the evaluation version and was running or test software
> (generating simulated data) and noticed that in VEE 7 the
> program slowed by
> 15-20%. The attached example was written in VEE 5.01 (I don't
> have access to
> 6.x) in Win2000. On my system the same program in VEE 5 takes
> on average
> 11ms to read 2000 real values from a file, while in VEE 7
> this is 21ms. This
> may not seem like alot, but we take all our data and perform
> post processing
> for different tests. On my simulated data I go from 7 minutes to 9.5
> minutes, but I have estimated with the test equipment this
> will add 1.5
> hours.
> I don't have access to VEE 6 so I don't know if this also
> occurred in that
> version, or if it is introduced in VEE 7. Any
> help/suggestions would be
> appreciated.
> Thanks,
> Lyle Carnahan
> Aerospace and Defense Business Unit
> M/A-COM  Inc.
> 1011 Pawtucket Boulevard
> Lowell, MA  01853-3295
> Phone: (978) 442-4504
> Fax:   (978) 442-4520
