Hi Scott,
Too bad the VEE port to Linux didn't work. Perhaps someday the
demand will be high enough for the project to be completed. Until
then, I'll continue looking into the open source alternatives. I
have a list of them with FlowDesigner at the top.
I've contacted the author of FD about adding an interface for calling
functions in a shared library. If this can be done, it may be
possible to add support for TCP, GPIB, and DAQ. It's a start
Anyway, this is a VEE forum. Thanks for the info.
-Kevin
On 04/07/04 17:11:04, scott_bayes@agilent.com wrote:
> Hi Kevin and the vrf,
> A few years ago, in a universe far away from VEE Support, I did
> some non-technical groundwork for a VEE port to Linux. For various
> reasons, some good, some bad, it fell through.
> Since then, I haven't seen any signs that such an effort will be
> revived, primarily because it doesn't appear there would be a
> sufficient number of customers for a Linux version to make it
> economical to expend the effort and resources. The effort would be
> pretty big, the resources valuable on VEE for Windows.
> I'd have to say "No, unless we see a lot more demand than we see
> now (or unless someone sends us a large truckfull of small unmarked
> bills), there probably won't be a Linux version of VEE".
> By the way, this doesn't get asked excessively on vrf though we do
> get occasional direct inquiries.
> Sorry,
> Scott Bayes
> Software Technical Support
> Agilent Technologies, Inc.
> 815 14th Street S.W.
> Loveland, CO, U.S.A. 80537
> 970 679 3799 Tel
> 970 635 6867 Fax
> > -----Original Message-----
> > From: Kevin Valentine [mailto:k.valentine@verizon.net]
> > Sent: Wednesday, April 07, 2004 10:54 AM
> > To: PDL-LISTS,VRF (A-Lists,unix1)
> > Subject: [vrf] VEE for Linux?
> > Greetings,
> > A client has asked me to develop an applicaton on a Linux server
> > using a graphical language like VEE or LabVIEW. I have used
> LabVIEW
> > for Linux but the client favors VEE because of its lower cost and
> > they have more in-house support for VEE. Also, since all their
> DAQ
> > modules have ethernet ports, they only need the TCP functions.
> > Are there plans (or rumors) to port VEE to Linux?
> > I found an open source IDE called FlowDesigner (see
> > flowdesigner.sourceforge.net) but it's in the early stages of
> > development. IMO, it looks more like VEE than LabVIEW.
> Presently,
> > there's no support for front panels, hardware, or the TCP
> > functions.
> > I'm betting it will be that way for some time.
> > Best regards,
> > Kevin Valentine
> > NOTE: Sorry if the Linux port question gets asked a lot. I'm new
> to
> > the list and there doesn't appear to be an archive or a FAQ.
> > Normally I'd lurk for about a month but a week is all I can give.
> I
> > need this info ASAP.
> > You are currently subscribed to vrf as: scott_bayes@agilent.com
> > To subscribe send a blank email to
> "join-vrf@it.lists.it.agilent.com".
> > To unsubscribe send a blank email to
> > "leave-vrf@it.lists.it.agilent.com".
> > To send messages to this mailing list, email "vrf@agilent.com".
> > If you need help with the mailing list send a message to
> > "owner-vrf@it.lists.it.agilent.com".
-Kevin
> Sorry,
> Scott Bayes
> 970 679 3799 Tel
> 970 635 6867 Fax
> > Greetings,
> LabVIEW
> DAQ
> Presently,
> > functions.
> > Best regards,
> > Kevin Valentine
> to
> I
