Hi, everyone,
sorry to raise question again.
Last time the micrometer unit problem was solved using python script.
However, this time, the unit is mm, still problem occurred.
Attached is the sample dxf file, after importing to EMPro 2011.12,
Error message "Wire bodies are not supported by FEM simulator" appeared.
Would you please kindly help me check this problem?
Really appreciate your help!
Yours,
Yiliu
Yours,
Yiliu
In EMPro it is possible to create a sheet body from a wire body, by first creating a sheet wih an empty sketch and then dragging the wire body to the "Sheet Body" item that is inside the Modeling Sequence in the Parts tree. An extrude can be created from a wirebody in a similar way.
Another solution is to edit the DXF file. Attached is the DXF file you submitted with the group code 70 of the LWPOLYLINEs set to 1.
