Hello everybody,
I've got the following problem and I hope somebody can help me:
I want to control an Excel application out of Vee using ActiveX.
I create the application (set my global variable "App", which points to ExcelApplication), make it visible and open an existing Excel file (set my global variable "Book", which points to the workbook). After that I display a Vee "Save" button to prevent Vee from going any further in its program flow. The user is supposed to enter data into the Excel sheet and press the "Save" button afterwards and then Vee is going to save the Excel Workbook and close/quit Excel.
As long as the user doesn't enter any data it works perfectly. But as soon as he does, I loose control over the Application/Workbook. That means my global Vee variables (Book, App), still point to the same address, but the type/object info is set to "null" (if I look at App for instance, it gives me something like: "(null)(0x0021f914)") and if I attempt to access the "SaveAs" method of "Book" then I get the error message: "SaveAs" is not a member of the referenced ActiveX object".
I'm using Vee 6.01, Excel 2000 and the Microsoft Excel 9.0 Object Library and I have the following code:
In a formula with input "filename":
set App=CreateObject("Excel.Application");
App.Visible=True;
App.Workbooks.Open(filename);
set Book=App.ActiveWorkbook;
The I call the "Save" button
Book.SaveAs(filename);
App.Quit();
Thanks for the help.
Kind Regards
Torsten
App.Visible=True;
App.Quit();
Kind Regards
Torsten
Does anyone have any example code for loading ESG (E4438C) waveform
files via GPIB.
A customer recently supplied us with a file containing a waveform, I
need to load it into our ESG.
I want to create a VEE program that will allow a user to select a
file from a folder, then have it load automatically into the ESG.
I do know that Agilent provides a free software platform that will
do this, however I would like to create a more custom
program for company.
David S. Wilson
RF Test Engineer
REMEC, INC.
*Phone: 949-260-1840 ext.142
* Fax: 949-260-0883
*Email: david.wilson@remec.com
