> HP 82335 ISA HPIB interface
Most of what you want to do sounds quite feasible, but this
one is a problem. This is a very old card that is not supported
by any modern OS (NT, 2K, XP) and unless you have an old
PC with an ISA slot you won't get too far.
Would strongly suggest moving to a more modern card-
or a USB/GPIB adpater or even a LAN/GPIB gateway.
Other than that first thing of course is to verify
that your hardware can make the measurements you need
in the time you want. With that in hand the VEE part
should be fairly simple.
Stan
Stan
use. Sounds like that would be better.
Thank you,
Kevin
> -----Original Message-----
> From: Stan Bischof [mailto:rsb@soco.agilent.com]
> Sent: Friday, June 04, 2004 5:43 PM
> To: VRF
> Cc: vrf@agilent.com
> Subject: [vrf] Re: new to VEE, data acquisition, recording,
> XY plotting
> program
> Stan
> You are currently subscribed to vrf as: watassek@swbell.net
