vrf Direct IO Error 601
Question asked by wwdyer on May 16, 2004
Does the box want to see the text representation of the hex value 1E or is it really expecting the actual binary value of 1E (which is a ctrl^, ASCII control character RS, record separator). If it want the actual binary 1E then you should be using a WRITE BYTE 0x1e which will output the correct control character.
From: TDaniels@moreycorp.com [mailto:TDaniels@moreycorp.com]
Sent: Friday, May 14, 2004 4:32 PM
To: VRF
Subject: [vrf] Re: Direct IO Error 601
Yep, your right.  That worked for me.  The equipment didn't respond as
expected, but the logger port says it received the command.
Tom Daniels
Test Engineer
The Morey Corporation
100 Morey Drive
Woodridge, IL 60517
T: (630) 754-2256
F: (630) 754-2656
tdaniels@moreycorp.com
             Stan Bischof
             (Richard S)
             <rsb@soco.agilent                                          To
             .com>                     VRF <vrf@agilent.com>
        cc
             05/14/04 03:20 PM         vrf@agilent.com
        Subject
             Please respond to
               Stan Bischof
                (Richard S)
             <rsb@soco.agilent
                   .com>
TDaniels@moreycorp.com wrote:
> Stan and vrf,
> I'm not using an input to the Direct IO box.  If I enter 1E into the
"data"
> field of the write transaction, then move the focus away (click elsewhere
> with the mouse), I get the error.
that's exactly what I figured- the 1E is being interpreted as a real
value and the syntax is indeed incorrect for a real value.
1e1   will not error since it is indeed correct syntax
If you are trying to write the string "1E" to your instrument then
put "1E"  (not 1E) in the data field
Stan
Stan Bischof  Agilent Technologies  707-577-3994  stan_bischof@agilent.com
You are currently subscribed to vrf as: TDaniels@moreycorp.com
You are currently subscribed to vrf as: wwdyer@lucent.com
