I have a declared variable 1 dim text 10 long I fill it will different
numbers of chars , how can I convert that array to a string to do a
comparison a==b etc or can I compare straight from array ?
when use to string I get non consistent results in the resultant string
Malcolm Bint
Malcolm Bint
It sounds like all you need is a formula box with sum(A). This concatenates
string arrays into a single string. If you are doing comparisons, be aware
that this will not distinguish between the arrays ["ab","c"] and ["a","bc"]
etc.
Bill Ossmann
Philips Ultrasound
e-mail: bill.ossmann@philips.com
Malcolm Bint
You are currently subscribed to vrf as: bill.ossmann@philips.com
