I'm still a little unclear on exactly what you want to do, but this looks
like an ideal use for a UserFunction. You can call it at point A during
startup, and again from within your loop without all the jumping around. It
makes for code that is much easier to understand and maintain.
Bill Ossmann
Philips Ultrasound
e-mail: bill.ossmann@philips.com
the topic is a little bit more complicated, than a single loop.
Below I have a diagram how the program looks like. When I 'm on the right
below loop and over a confirm button I want end the loop and jump to point
A.
Doing some presetting for the filereader and then back to the loop below.
Up to now I got always the message 'illegal use inside a loop' ?
Thomas
-------- Original Message --------
Subject: [vrf] RE: [VRF] problems with loops (06-Mai-2004 16:54)
To: tw@huber-online.com
> Also look at the Next and Break blocks available under Flow->Repeat. The
> Next block forces the loop to start the next cycle, and the Break block
> forces the loop to exit.
> Bill Ossmann
> Philips Ultrasound
> > now I want finish a loop and jump one instance above the loop.
> > Than I get the message illegal use of loop functions.
> Sounds like the problem everyone has when they make their first
> "loop."
> In VEE, a loop doesn't look like a loop - that is, you don't wire
the
> end point to the top. Instead, go to Flow->Repeat, and select the
> object
> that is closest to the type of loop that you want. Its output is
> connected
> to the top of your loop.
> Les Hammer
> Partner
> Complete Test
> 720 SW 14th St.
> Loveland, CO. 80537
> Les.Hammer@CompleteTest.com
> You are currently subscribed to vrf as: bill.ossmann@philips.com
> You are currently subscribed to vrf as: tw@huber-online.com
> If you need help with the mailing list send a message to "owner-vrf@it.
> To: vrf@agilent.com
To: bill.ossmann@philips.com
Cc: vrf@agilent.com
[attachment "_0507090117_001.tif" deleted by Bill Ossmann/ANR/MS/PHILIPS]
Bill Ossmann
Philips Ultrasound
"loop."
In VEE, a loop doesn't look like a loop - that is, you don't wire the
object
connected
Les Hammer
Partner
Complete Test
720 SW 14th St.
Loveland, CO. 80537
