Hello Vinod,
Thanks for your help. It works. This technique uses 'tab' a few times to
get the 'enter' function right?
Can I use "F1" or other keys to achieve the effect as well? Is there a
solution for it?
Tried to use oWsh.SendKeys("{Enter}") but this doesn't work for me.
Thanks again.
Warm Regards,
Eng Chye, Neo (Rongcai, Liang)
Measurement Application Engineer
Asia Measurement Response Center
Measurement Application Services
Agilent Technologies, Inc.
www.agilent.com
Sent: Wednesday, June 30, 2004 12:00 PM
Subject: [vrf] Re: Jumping from one input to another
Hello Eng Chye,
--- "NEO,ENG-CHYE (A-Singapore,ex1)" <eng-chye_neo@agilent.com> wrote:
> Can I include the function such that after I input in the first box,
> and by pressing 'enter' or any other key I so choose, to move to
> another 'entry' box, either to the right first or downwards.
Check out if the attached example works for you...
-Vinod
__________________________________
Do you Yahoo!?
Yahoo! Mail Address AutoComplete - You start. We finish.
http://promotions.yahoo.com/new_mail
solution for it?
Thanks again.
Warm Regards,
www.agilent.com
Hello Eng Chye,
-Vinod
Do you Yahoo!?
currently I'm trying to import stored data from a Vee program into Labview. This data is in the "dataset" format which labview doesn't recognise.
I could make some kind of low-level parser (in Vee?) and convert it to a format that is know by labview (XML?). There are nested records in the datasets.
What would be the best solution to tackle this?
Best regards,
Tom
__________________
Tom Daenen
IMEC
SPDT/HiRel-Flash
Kapeldreef 75
B-3001 Heverlee
tel.: +32 16/28.87.13
fax.: +32 16/28.17.06
Tom.Daenen@imec.be
