hello,
I tried it on different ways, but up to now only the way, which you also called is, to do it with a UserFunction/UserObject is possible.
When I try get out of the loop in the level higher, it seems to be not solveable.
Thanks for your support.
Thomas
-------- Original Message --------
Subject: [vrf] RE: [VRF] problems with loops (10-Mai-2004 15:28)
To: tw@huber-online.com
> I'm still a little unclear on exactly what you want to do, but this looks
> like an ideal use for a UserFunction. You can call it at point A during
> startup, and again from within your loop without all the jumping around. It
> makes for code that is much easier to understand and maintain.
> Regards,
> Bill Ossmann
> Philips Ultrasound
> e-mail: bill.ossmann@philips.com
> Hi,
> the topic is a little bit more complicated, than a single loop.
> Below I have a diagram how the program looks like. When I 'm on the right
> below loop and over a confirm button I want end the loop and jump to point
> A.
> Doing some presetting for the filereader and then back to the loop below.
> Up to now I got always the message 'illegal use inside a loop' ?
> Thomas
> Subject: [vrf] RE: [VRF] problems with loops (06-Mai-2004 16:54)
> From: bill.ossmann@philips.com
> > Also look at the Next and Break blocks available under Flow->Repeat. The
> > Next block forces the loop to start the next cycle, and the Break block
> > forces the loop to exit.
> > Bill Ossmann
> > Philips Ultrasound
> > > now I want finish a loop and jump one instance above the loop.
> > > Than I get the message illegal use of loop functions.
> > Sounds like the problem everyone has when they make their first
> > "loop."
> > In VEE, a loop doesn't look like a loop - that is, you don't wire
> the
> > end point to the top. Instead, go to Flow->Repeat, and select the
> > object
> > that is closest to the type of loop that you want. Its output is
> > connected
> > to the top of your loop.
> > Les Hammer
> > Partner
> > Complete Test
> > 720 SW 14th St.
> > Loveland, CO. 80537
> > Les.Hammer@CompleteTest.com
> > You are currently subscribed to vrf as: bill.ossmann@philips.com
> > To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".
> > To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".
> > To send messages to this mailing list, email "vrf@agilent.com".
> > If you need help with the mailing list send a message to
> > "owner-vrf@it.lists.it.agilent.com".
> > You are currently subscribed to vrf as: tw@huber-online.com
> > If you need help with the mailing list send a message to "owner-vrf@it.
> > To: vrf@agilent.com
> To: bill.ossmann@philips.com
> Cc: vrf@agilent.com
> [attachment "_0507090117_001.tif" deleted by Bill Ossmann/ANR/MS/PHILIPS]
> To: vrf@agilent.com
vrf@agilent.com
Thomas
> Regards,
> Bill Ossmann
> Philips Ultrasound
> Hi,
> A.
> Thomas
> > Bill Ossmann
> > Philips Ultrasound
> > "loop."
> the
> > object
> > connected
> > Les Hammer
> > Partner
> > Complete Test
> > 720 SW 14th St.
> > Loveland, CO. 80537
> > To: vrf@agilent.com
> Cc: vrf@agilent.com
> To: vrf@agilent.com
vrf@agilent.com
