"Shawn Fessenden <shawn@testech-ltd.com> wrote:
> > "Print Screen" captures the entire screen
> > Alt-"Print Screen" capttures just the active window
> Of course with VEE "active window" means the VEE window, not just the active
> panel or dialog.
For the active panel or dialog- or objects for that matter, you
can generally use std Windows cliboard.
i.e. good old ctrl-c (copy) and ctrl-v (paste).
Stan
> panel or dialog.
Stan
1. Press <PRINT SCREEN> - Puts the entire screen on the clipboard
2. Press <ALT><PRINT SCREEN> - Puts the active window on the clipboard
(Great for capturing Popup screens)
Then open paint, word,... And hit paste( or <CTRL><V>) and you get the
screen shot you want.
I know there are commercial packages that allow you to draw a selection
rectangle around a portion of the screen, but a full screen capture, pasted
into MS-Paint, would then allow you to select and copy out any portion of
the screen you wanted.
Why spend money if you don't have to.
v/r
Mike
Michael N. Asbery (202)404-3014, DSN 754
US Naval Research Laboratory fax (202)404-7661
Code 5733.20 michael.asbery@nrl.navy.mil
4555 Overlook Ave SW
Washington DC 20375
From: Baranski, Detlef [mailto:Detlef.Baranski@PILKINGTON.de]
Sent: Thursday, July 01, 2004 2:36 AM
To: VRF
Subject: [vrf] AW: RE: VEEs are not found /Screenshot
Incidentally how did you capture the screenshot?
Gregg C Levine hansolofalcon@worldnet.att.net
hello Greg,
making a screenshot is a built in windows function...but it is not well
known ;-(
Press the Print ( Or Druck ) button. That captures the actual sceeen. Then
go to a paint program like MS-Paint and insert it via ctrl- V or via insert
menu.
If you need better capture facility there are some extra programs available
like Hypersnap DX.
Best regards,
detlef
This message and any attachments are confidential, for the exclusive use of
the addressee and may be legally privileged. Any other distribution, use or
reproduction is unauthorised and prohibited. If you have received this
message in error, please notify the sender immediately and delete the
message from your system.
Visit our internet site at http://www.pilkington.com
You are currently subscribed to vrf as: michael.asbery@nrl.navy.mil To
