<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><META http-equiv=Content-Type content="text/html; charset=us-ascii"><META content="MSHTML 6.00.2800.1400" name=GENERATOR><STYLE></STYLE></HEAD><BODY bgColor=#ffffff><DIV dir=ltr align=left><DIV dir=ltr align=left><SPAN class=192442512-18062004><FONT face=Arial color=#0000ff size=2>If you're intent upon using a device with imprecision, then take advantage. What I mean is define a simple linear control from the data you receive. Data acquisition must be fast enough or the control must compensate for all areas of imprecision. You will need the velocity and the acceleration from the <SPAN class=538214712-18062004>sensor </SPAN>data<SPAN class=538214712-18062004>, the more sensor points the better</SPAN>. Essentially what you will build is an adaptive control. Since you overshoot or undershoot you will need to adjust the control when near the set point.</FONT></SPAN></DIV><DIV dir=ltr align=left><SPAN class=192442512-18062004><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV><DIV dir=ltr align=left><SPAN class=192442512-18062004><FONT face=Arial color=#0000ff size=2>You<SPAN class=538214712-18062004>r</SPAN> logic must contain location (say the variable is X(t) you will need its value), velocity(X'(t)=V, and the acceleration, X''(t) =A.</FONT></SPAN></DIV><DIV dir=ltr align=left><SPAN class=192442512-18062004><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV><DIV dir=ltr align=left><SPAN class=192442512-18062004><FONT face=Arial color=#0000ff size=2>Then work out the control scenario along the trajectory, something like:</FONT></SPAN></DIV><DIV dir=ltr align=left><SPAN class=192442512-18062004><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV><DIV dir=ltr align=left><SPAN class=192442512-18062004><FONT face=Arial color=#0000ff size=2>if X is x1 and V is v1 and A is a1 then U is u1</FONT></SPAN></DIV><DIV><SPAN class=192442512-18062004><FONT face=Arial color=#0000ff size=2>if X is x2 and V is v2 and A is a2 then U is u2</FONT></SPAN></DIV><DIV><SPAN class=192442512-18062004></SPAN><SPAN class=192442512-18062004></SPAN><FONT face=Arial color=#0000ff size=2>.</FONT></DIV><DIV><SPAN class=192442512-18062004></SPAN><FONT face=Arial color=#0000ff size=2>.</FONT></DIV><DIV><SPAN class=192442512-18062004></SPAN><FONT face=Arial color=#0000ff size=2>.</FONT></DIV><DIV><SPAN class=192442512-18062004><FONT face=Arial color=#0000ff size=2>if X is xn and V is vn and A is "an" then U is un</FONT></SPAN></DIV><DIV><SPAN class=192442512-18062004><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV><DIV><SPAN class=192442512-18062004><SPAN class=538214712-18062004><FONT face=Arial color=#0000ff size=2>Where U is the control. Note each variable may be a vector.</FONT></SPAN></SPAN></DIV><DIV><SPAN class=192442512-18062004><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV><DIV><SPAN class=192442512-18062004><FONT face=Arial color=#0000ff size=2>If you wish to be fancy like the Japanese then include your i<SPAN class=538214712-18062004>m</SPAN>pre<SPAN class=538214712-18062004>cision</SPAN>, that is<SPAN class=538214712-18062004>,</SPAN> call each point for each variable a set of points that it could be with the value in question as the mid-point(don't have to be midpoint, I just like it there and I use a triangular shape for the set), choose a shape for your set that represents the data. Then if a member of multiple sets take the arithmetic mean, make sure adjacent sets overlap. Simpler would be to define a continuous value for set membership, that is a value from 0 to 1 where for X, membership in x1 is for the positive ramp ... oh this will take too much time. </FONT></SPAN></DIV><DIV><SPAN class=192442512-18062004><FONT face=Arial color=#0000ff size=2></FONT></SPAN><SPAN class=192442512-18062004><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV><DIV><SPAN class=192442512-18062004><FONT face=Arial><FONT color=#0000ff><FONT size=2>So if you define controls for the above and track the deceleration then you will get close enough fast enough.<SPAN class=538214712-18062004> This will also work for non-linear controls, which is the reason for it's existence.</SPAN></FONT></FONT></FONT></SPAN></DIV><DIV><SPAN class=192442512-18062004><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV><DIV><SPAN class=192442512-18062004><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV><DIV><SPAN class=192442512-18062004><FONT face=Arial color=#0000ff size=2>Rufus</FONT></SPAN></DIV></DIV><BR><DIV class=OutlookMessageHeader lang=en-us dir=ltr align=left><HR tabIndex=-1><FONT face=Tahoma size=2><B>From:</B> George Tyrrell [mailto:tdllc01@earthlink.net] <BR><B>Sent:</B> Thursday, June 17, 2004 12:01 AM<BR><B>To:</B> VRF<BR><B>Subject:</B> [vrf] Re: PID and Deadbeat controllers<BR></FONT><BR></DIV><DIV></DIV><DIV><FONT face=Arial size=2>Michael,</FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2>Most all computers, especially those connected to a network, will have some erratic latency which will really disrupt a PID algorithm.</FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2>I use Yokogawa UD550 PID controllers - ultra reliable, once they are set up, they run forever with no erratic performance. I control pressures in a chamber using mass-flow control valves and vacuum pumps. If the PID stalls, it can easily overpressure or underpressure. The Yokogawa controller eliminates that problem. Also, you probably don't have enough time to emulate all the capability that exists in these controllers.</FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2>The interface is on RS-485, easily obtained with the NI PCI card or RE Smith RS-232 converters or B&B converters.</FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2>By the way, don't get a controller on ModBus - you'll spend way too much time on the interface control.</FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2>George Tyrrell</FONT></DIV><DIV><FONT face=Arial size=2>TestDynamics LLC</FONT></DIV><DIV><FONT face=Arial size=2>Thornton, Colorado</FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><BLOCKQUOTE style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px"> <DIV style="FONT: 10pt arial">----- Original Message ----- </DIV> <DIV style="BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: black"><B>From:</B> <A title=MFord@Generalmicrowave.com href="mailto:MFord@Generalmicrowave.com">Ford, Michael</A> </DIV> <DIV style="FONT: 10pt arial"><B>To:</B> <A title=vrf@agilent.com href="mailto:vrf@agilent.com">VRF</A> </DIV> <DIV style="FONT: 10pt arial"><B>Sent:</B> Tuesday, June 15, 2004 1:09 PM</DIV> <DIV style="FONT: 10pt arial"><B>Subject:</B> [vrf] PID and Deadbeat controllers</DIV> <DIV><BR></DIV> <DIV><FONT face=Arial size=2><SPAN class=167464917-15062004>Has anyone out there ever tried implementing a <STRONG>PID</STRONG> (Proportional,Integral, and Derivative) or <STRONG>Deadbeat temperature controller</STRONG> in VEE.</SPAN></FONT></DIV> <DIV><FONT face=Arial size=2><SPAN class=167464917-15062004></SPAN></FONT> </DIV> <DIV><FONT face=Arial size=2><SPAN class=167464917-15062004>I'm trying to optimize a temperature profile routine using a Sigma C4 temperature plate. I'm need to reach my desired temperature in optimum time with minimum overshoot. The catch is; it needs to be generic enough to work in all cases regardless of DUT Mass and Thermal characteristics.</SPAN></FONT></DIV> <DIV><FONT face=Arial size=2><SPAN class=167464917-15062004></SPAN></FONT> </DIV> <DIV><FONT face=Arial size=2><SPAN class=167464917-15062004>My original plan of attack was to monitor both the Temperature Plate and the DUT temperature for rate of change (slope).</SPAN></FONT></DIV> <DIV><FONT face=Arial size=2><SPAN class=167464917-15062004>Then, I increase the absolute Plate setpoint to increase the DUT rate of change(Slope). </SPAN></FONT></DIV> <DIV><FONT face=Arial size=2><SPAN class=167464917-15062004>When the DUT aproaches the desired temp, I decrease the absolute Plate setpoint to decrease the DUT rate of change(Slope) to avoid overshoot.</SPAN></FONT></DIV> <DIV><FONT face=Arial size=2><SPAN class=167464917-15062004></SPAN></FONT> </DIV> <DIV><FONT face=Arial size=2><SPAN class=167464917-15062004>As you might have guessed this is easier said than done. I need more thermal resolution than I can supply thusfar. As I vary Temperature swings, Mass and Thermal Characteristics, all of my solutions go to *#&!@@#. </SPAN></FONT></DIV> <DIV><FONT face=Arial size=2><SPAN class=167464917-15062004></SPAN></FONT> </DIV> <DIV><FONT face=Arial><FONT size=2><FONT size=+0><SPAN class=167464917-15062004>One of our design engineers has suggested the PID and Deadbeat solution, but the reading material provided is extremely dense. I'm hoping one of you guys have already been there before I try and reinvent the wheel.</SPAN></FONT></FONT></FONT></DIV> <DIV><FONT face=Arial><FONT size=2><FONT size=+0><SPAN class=167464917-15062004></SPAN></FONT></FONT></FONT> </DIV> <DIV><FONT face=Arial><FONT size=2><FONT size=+0><SPAN class=167464917-15062004>Thanks,</SPAN></FONT></FONT></FONT></DIV> <DIV><FONT face=Arial><FONT size=2><SPAN class=167464917-15062004></SPAN></FONT></FONT> </DIV> <DIV><FONT face=Arial><FONT size=2><SPAN class=167464917-15062004></SPAN></FONT></FONT> </DIV> <DIV><FONT face=Arial><FONT size=2><SPAN class=167464917-15062004></SPAN></FONT></FONT><FONT face="Century Gothic"><FONT face="Century Gothic" size=2><STRONG>Michael Ford</STRONG></FONT></DIV> <DIV> <DIV><FONT face=Arial size=2>Test Engineering</FONT></DIV> <DIV><FONT face=Arial size=2>Herley Farmingdale</FONT></DIV> <DIV><FONT face=Arial size=2>425 Smith Street Farmingdale, NY 11735-1198</FONT></DIV> <DIV><FONT face=Arial size=2>(phone) 631.630.2000 ext 268 (fax) 631.630.2066</FONT></DIV> <DIV><FONT face=Arial><SPAN class=284475519-02032004><FONT face="Century Gothic"><A href="mailto:Michael.Ford@Herley.com"><FONT color=#000000 size=2>mailto:</FONT></FONT></SPAN><FONT color=#000000 size=2>Michael.Ford@Herley.com</FONT></A></FONT></DIV> <DIV><FONT face=Arial size=2></FONT> </DIV></FONT></DIV></BLOCKQUOTE>---<BR>You are currently subscribed to vrf as: rwarren@amti.net<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></HTML>
I haven't used the Agilent controllers, but I HAVE used the Omega
ones and was very happy with the results. Check 'em out at...
http://www.omega.com/guides/temperaturecontrollers.html
Cheers!
Mike Groves
From: Kevin R. Watassek [mailto:watassek@swbell.net]
Sent: Tuesday, June 15, 2004 1:43 PM
To: VRF
Subject: [vrf] Re: PID and Deadbeat controllers
I have looked at the example and the demo runs well, it does sometimes go
unstable. I am actually considering using this. On the DUT and temperature
plate would it make sense to setup some initial parameters based on expected
system response using a matrix for pid selection based on initial expected
system response, kind of fuzzy logic based on if then else if.
On a similar item, what about the use of the Agilent E1415 algorithmic
closed loop controller???? I am considering using this. Does anyone have
experience with it???
Kevin
> From: bill.ossmann@philips.com [mailto:bill.ossmann@philips.com]
> Sent: Tuesday, June 15, 2004 3:12 PM
> To: VRF
> I've not done this myself, but there is an example of a PID
> controller in
> the Vee examples/Applications called pid.vee that might get
> you started.
> Bill Ossmann
> Philips Ultrasound
> Has anyone out there ever tried implementing a PID
> and Derivative) or Deadbeat temperature controller in VEE.
> in optimum time
> enough to work
> DUT rate of
> change(Slope).
> Temperature swings,
> Deadbeat solution,
> hoping one of you
> Thanks,
> Michael Ford
> Test Engineering
> Herley Farmingdale
> You are currently subscribed to vrf as: bill.ossmann@philips.com
> You are currently subscribed to vrf as: watassek@swbell.net
You are currently subscribed to vrf as: mikegroves@pacbell.net
