> When I assumed the responsibility of maintaining our test systems,
> I was told that the logical unit numbers were selected from a
> recommended list from HP (now Agilent).
As far as I'm aware (and anyone please correct me if I'm wrong) these
numbers come from seriously ANCIENT hardware and have nothing to do with
recent times.
Your Series 80 HPIB pods came set to ISR 7 and the PIO pods came set to ISR
6. Serial was 9. There was a little dial on the back that you could turn to
different numbers, but hardly anybody ever did. This scheme was simply
perpetuated down the ages to IO Libs (and that's about the right term -
ages - we're talking about more than 20 years ago).
These numbers have really no meaning what so ever, except for the magic
number 14. By default, this number is reserved (or something like that) for
NI hardware. I have exactly one example of using NI hardware in an otherwise
HP/Agilent test system and it works fine at 7. Les or Jay can probably shed
some light on 14. I stay away from it. I've had troubles with LU14 when
assigning a large block of serial ports so I start them at 21 instead of 1.
-SHAWN-
recent times.
-SHAWN-
When I assumed the responsibility of maintaining our test systems, I was
told that the logical unit numbers were selected from a recommended list
from HP (now Agilent). The logical unit numbers used to assign
instrumentation in the IO libraries usually default to a number for logical
unit (GPIB is 7, VXI is 16, our com ports use 9 and 5 and DIO is 6). Is
there in fact a list of recommended logical unit numbers to use for system
standards (including any reserved numbers) or is if left to me to decide by
trial and error?
Larry Hartley
Senior Test Engineer II
903-457-6245
larry.hartley@L-3com.com
