In the VEE 7.0 help about how to use IVI-COM drivers, it says...
Agilent recommends that you use the Device > .NET Assembly References COM
tab rather than ActiveX. It will supply more of the types necessary for the
use of the IVI driver.
I'm no expert at either COM or .Net. Can someone explain what sort of
types fall into this category, or can you give me a specific example?
Thanks.
Brian
Thanks.
Brian
