Hi Folks,
I received the following a few days ago from "Lyris ListManager"
<lyris@it.lists.it.agilent.com>:
> This email message is to notify you that your membership to vrf
> has been put on "hold".
> This means that you will not receive mail from 'vrf'.
> Your subscription has been held because at least 5 recent messages have been
> either bounced by your email system, or could not be delivered at all.
> Note that if your email address continues to reject mail your subscription will
> once again be "held".
As you might expect, my incoming mail must pass through a firewall and
this is what's causing the rejections. I looked at the "rejected
message" list (103 messages in the last 5 days) and I can't see anything
that the firewall appears to have done incorrectly. In fact, at least
2/3 of the rejects definitely contained viruses. I don't know what
world the "Lyris Listmanager" is living in but refusing "5 recent
messages" has got to be "normal and expected" for most of us. Also, I
wonder how the "ListManager" actually determines that a given message
was really sent by one of us and shouldn't have been rejected.
Unfortunately, I can't determine what vrf messages were rejected - the
list I looked at had only one obvious vrf sender. In general, our
firewall is not happy with .exe attachments (at the moment) but I rarely
see these with vrf messages (all rejected?). So, apparently, there is
nothing I can do to prevent getting kicked off the vrf in the future
and, even if there was, loosening our firewall because it rejected 5
questionable messages doesn't seem too bright.
Barrie
whoi
Barrie
whoi
Very strange.
Barrie, did you by chance at the VEE days seminar last year hear about
the Yahoo Groups archival arrangement for our list? Check there. Your
missing messages(?) are probably stored there, without the infected
attachments of course. That's where I found the one that Shawn, and
company were discussing.
Personally I'm convinced that particular list server does not even
live on our world. I'm not sure which one, but it is not here.
Gregg C Levine hansolofalcon@worldnet.att.net
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke." Obi-Wan Kenobi
> -----Original Message-----
> From: Barrie Walden [mailto:bwalden@whoi.edu]
> Sent: Tuesday, May 11, 2004 2:02 PM
> To: VRF
> Subject: [vrf] Viruses, Firewalls and vrf on "Hold"
> Hi Folks,
have been
all.
subscription will
and
anything
least
I
message
the
rarely
is
> Barrie
> whoi
