vrf Binary test 1D array to Hex data 1D array
Question asked by VRFuser on May 4, 2004
Thank you. This works.
-Dale
From: Schlieker, Reiner [mailto:reiner.schlieker@siemens.com]
Sent: Tuesday, May 04, 2004 12:49 PM
To: VRF
Subject: [vrf] RE: Binary test 1D array to Hex data 1D array
You can use the bits() function to convert the binary strings to integers,
and the To String object to convert the integers to hex strings.  You'd have
to play around with the formatting to get it in the format you want.
Reiner
From: Zhang, Dale [mailto:zhangd@tycoelectronics.com]
Sent: Tuesday, May 04, 2004 12:21 PM
To: VRF
Subject: [vrf] Binary test 1D array to Hex data 1D array
Does anyone have experience to accomplish the above task?
For example, convert
from (binary text)
11100011111
01100110111
to (hex data)
07 1f
06 37
Thank you. -Dale
You are currently subscribed to vrf as: reiner.schlieker@siemens.com
You are currently subscribed to vrf as: zhangd@tycoelectronics.com
