A couple of things to look out for with the scope. Make sure that the
preamble is set to be either always on or always off. If you are requesting
a measurement like freq, pulsewidth etc, make sure that you have a valid
waveform. Check the trigger status to make sure that the scope is being
triggered.
From: MORRISON,SCOTT (A-Sonoma,ex1) [mailto:scott_morrison@agilent.com]
Sent: Monday, June 07, 2004 9:37 AM
To: VRF
Subject: [vrf] Re: Weird data flow
I'd also suggest that the instrument's output data format matches that of
what your prog is expecting. If the prog was written while the data output
was type 'A', but the instrument defaults to type 'B' you can have problems
if the output type is not set by the prog....
-Scott
Sent: Monday, June 07, 2004 8:36 AM
Cc: PDL-LISTS,VRF (A-Lists,unix1)
Maria Sanchez-Bordona <msbordona@cenita.com> wrote:
> > Turn on "show execution flow" (the green "dumbell" on the toolbar) and
see
> > if you can identify the last object that fired before it hangs. Some of
the
> > user interface elements do this by design, but it sounds like you might
> > have a configuration problem. Are the instruments receiving the commands
> > you send?
> It hangs reading a measure from the oscilloscope but the thing is, I
haven't
> changed that object and it worked two days ago!.
In that case first thing I would check is the hardware. reboot the scope,
make sure that the GPIB bus is cleared. Manually perform the measurement
you are making
Then if that doesn't work turn on the bus monitor
and make sure that the commands you are sending and receiving are
correct. Something may have changed without you realizing it.
regards
Stan
You are currently subscribed to vrf as: scott_morrison@agilent.com
You are currently subscribed to vrf as: RPratt@symmetricom.com
triggered.
To: VRF
-Scott
see
the
> > you send?
haven't
you are making
regards
Stan
