Hi Malcolm,
here is also a Tool to get back your deleted files ....
http://www.ontrack.com/easyrecoverydatarecovery/
Regards Thomas
Thomas Hauke
MEDER electronic GmbH
thauke@meder.com
Sent: Monday, May 24, 2004 10:49 AM
To: VRF
Subject: [vrf] HELP!
I have deleted both the .VEE amd .BAK files. I have the the "RUNtime" and it
works fime.. Is there anyway back to the source!!!! Vee 5.0
Malcolm
You are currently subscribed to vrf as: thauke@meder.com
Regards Thomas
Thomas Hauke
thauke@meder.com
To: VRF
Malcolm
> of steps for a servo motor and the number is not remaining constant.
> I put in 26009.6 in the real32 constant and get a distorted value.
Unfortuantely that's the way real32 behaves. There's no way to represent
most numbers *exactly*. Formulas and instruments need to be tolerant of
approximations.
Can you modify your formula to have 260096 as an int32 input and divide
by 10 in the formula?
Les Hammer
Vice President
Complete Test
