That's just what I was looking for.
Thank you again.
Milan
> -----Original Message-----
> From: Kevin.Hasselquist@nokia.com [SMTP:Kevin.Hasselquist@nokia.com]
> Sent: Friday, May 21, 2004 11:49 AM
> To: VRF
> Subject: [vrf] RE: pause data collection based on value
> An If-Then-Else and a gate should work
> From: ext Bourland, Milan [mailto:mbourland@PhelpsDodge.com]
> Sent: 21 May, 2004 8:12 AM
> To: VRF
> Subject: [vrf] pause data collection based on value
> Hello:
> I am new to this, have no prior programming experience and have had no
> training. Please be patient with me.
> I am monitoring a piece of equipment and sending the data collected to an
> Excel file. I am wondering if I can cause the data collection to pause if
> the value goes below a specific level and then restart if it increases
> above
> that level. For example, one of the variables I am looking at is voltage.
> If
> I am normally seeing 2.5 volts, can I cause the data collection to pause
> if
> the voltage level drops below 0.5 and then start collecting again when it
> rises back above 0.5?
> Thank you.
> Milan
> This message (including attachments) is for the designated recipient only
> and may contain privileged, proprietary, or otherwise confidential
> information. If you are not the intended recipient or have received this
> message in error, please notify the sender immediately and delete the
> original. Any other use of this e-mail is prohibited.
> Este mensaje (incluyendo los archivos adjuntos) est dirigido slo al
> receptor sealado y puede contener informacin de carcter privilegiada,
> privada o confidencial. Si usted no es el receptor sealado o bien ha
> recibido este mensaje por error, por favor notifique inmediatamente al
> remitente y elimine el mensaje original. Cualquier otro uso de este
> mensaje de correo electrnico est prohibido.
> You are currently subscribed to vrf as: Kevin.Hasselquist@nokia.com
> "owner-vrf@it.lists.it.agilent.com". << File: PauseDataCollection.vee >>
> << File: footer >>
This message (including attachments) is for the designated recipient only and may contain privileged, proprietary, or otherwise confidential information. If you are not the intended recipient or have received this message in error, please notify the sender immediately and delete the original. Any other use of this e-mail is prohibited.
Este mensaje (incluyendo los archivos adjuntos) est dirigido slo al receptor sealado y puede contener informacin de carcter privilegiada, privada o confidencial. Si usted no es el receptor sealado o bien ha recibido este mensaje por error, por favor notifique inmediatamente al remitente y elimine el mensaje original. Cualquier otro uso de este mensaje de correo electrnico est prohibido.
Thank you again.
Milan
> To: VRF
> To: VRF
> Hello:
> above
> If
> if
> Thank you.
> Milan
> << File: footer >>
the value goes below a specific level and then restart if it increases above
that level. For example, one of the variables I am looking at is voltage. If
I am normally seeing 2.5 volts, can I cause the data collection to pause if
Thank you.
Milan
