Robert,
Try "execute close" or "execute rewind" transactions in your from file
object.
Warren
Sent: 12 May 2004 09:50
To: VRF
Subject: [vrf] Error 701: End of file or no data found
Hi All!
I try to access a file several times but in the second trial I get this
error 701. Is there a way to reset the Vee file pointer so that Vee
reopens the file but not only increment the file handle internally.
Thanx in advance!
__________________________________________________________________
Robert Hemp
RST Raumfahrt Systemtechnik GmbH
Bahnhofstr. 108
D-88682 Salem
Tel: +49-7553-827915
Fax: +49-7553-827911
eMail: r.hemp@rst-group.biz
Web: www.rst-group.biz
You are currently subscribed to vrf as: Warren.Pickles@tycoelectronics.com
object.
Warren
To: VRF
Hi All!
Thanx in advance!
Robert Hemp
Bahnhofstr. 108
D-88682 Salem
use the 'Execute Rewind' tansaction to reset the read/write pointer.
best regards,
G. Nied
Georg Nied - Software-Development - Hansestr.7 - 51149 Cologne - Germany
Tel: +49 2203 9770915 - Fax: +49 2203 9770924 - eMail:info@gn-software.de
> Hi All!
To: r.hemp@rst-group.biz
vrf@agilent.com
