vrf AW: XY Trace Object with 26 Traces?
Question asked by VRFuser on May 18, 2004
Try this one
http://www.wilhelm-kurz-software.de/dynaplot/dynaplot.htm
Best Regards,
Dr. Peter Kraemmer
Siemens AG
Dept. CT PS 6
Paul Gossen Str. 100
91052 Erlangen
Germany
Tel. +49 9131 7 31080
Fax  +49 9131 7 32164
E-mail: peter.kraemmer@siemens.com
Von: mer Akbas [mailto:omer.akbas@arcelik.com]
Gesendet am: Montag, 17. Mai 2004 14:08
An: VRF
Betreff: [vrf] XY Trace Object with 26 Traces?
Dear Vrf,
I need an XY trace object with 26 traces. The regular XY trace allows only
12 traces. I tried to multiplex all 26 channels into a single trace but it
did not help because each trace should be clearly distinguished from the
others by color or something else. Any suggestions?
Regards
Omer Akbas
Arcelik, Istanbul
Bu e-posta mesaji kisiye zel olup, gizli bilgiler ieriyor olabilir. Eger
bu e-posta mesaji size yanlislikla ulasmissa, e-posta mesajini kullaniciya
hemen geri gnderiniz ve mesaj kutunuzdan siliniz. Bu e-posta mesaji, hi
bir sekilde, herhangi bir ama iin ogaltilamaz, yayinlanamaz ve para
karsiligi satilamaz. Yollayici, bu e-posta mesajinin - virs koruma
sistemleri ile kontrol ediliyor olsa bile - virs iermedigini garanti etmez
ve meydana gelebilecek zararlardan dogacak hibir sorumlulugu kabul etmez.
The information contained in this message is confidential, intended solely
for the use of the individual or entity to whom it is addressed and may be
protected by professional secrecy. You should not copy, disclose or
distribute this information for any purpose.
If you are not the intended recipient of this message or you receive this
mail in error, you should refrain from making any use of the contents and
from opening any attachment. In that case, please notify the sender
immediately and return the message to the sender, then, delete and destroy
all copies.
This e-mail message has been swept by anti-virus systems for the presence of
computer viruses. In doing so, however, we cannot warrant that virus or
other forms of data corruption may not be present and we do not take any
responsibility in any occurrence.
