"Kjell Ring (KI/EAB)" <kjell.ring@ericsson.com> wrote:
> Hello!
> I have problem with running matlab with VEE7.0 .
> I have matlab version 6.0 release 12 installed on my computer, and after i
> installed VEE7.0
> it didn't work to run the matlab vee examples. Error message: "Could not start
> MATLAB Script Engine (-3)".
> I had the same problem with VEE6.1 after installing matlab on my computer (it
> worked before i installed matlab).
> Does anyone have any suggestion?
> /Kjell
When I have seen this happen it is due to registration of the ActiveX
interface of Matlab.
try bringing up a command line
cd over to wherever you have VEE 7 installed
cd matlab inwin32
.matlab /regserver
That should register the Matlab engine that comes with VEE and
get you up and running.
regards
Stan
> Hello!
> installed VEE7.0
> /Kjell
cd matlab inwin32
.matlab /regserver
regards
Stan
I think the problem is that it is trying to locate a license file for matlab. The other possibility is that matlab is not properly registered. There is some help in VEE7 that talks about that. Search for Matlab Script in the help and look at Multiple Matlab Versions.
We haven't got to the full solution for this problem.
Adam Kohler
Software Test
EPSG
Scotland
tel net 313 5327
t +44 131 335 7327
e adam_kohler@agilent.com
From: Kjell Ring (KI/EAB) [mailto:kjell.ring@ericsson.com]
Sent: Thu 13 May 2004 10:51
Subject: [vrf] Matlab not running with VEE7.0
Hello!
I have matlab version 6.0 release 12 installed on my computer, and after i installed VEE7.0
it didn't work to run the matlab vee examples. Error message: "Could not start MATLAB Script Engine (-3)".
I had the same problem with VEE6.1 after installing matlab on my computer (it worked before i installed matlab).
/Kjell
You are currently subscribed to vrf as: adam_kohler@agilent.com
