Hi all,
I use the HP5373A Modulation Domain Pulse Analyzer to measure a PSK-Signal.
The MDPA is controlled over HP VEE.
First the program configures the MDPA.
Then, when the MDPA is waiting for a trigger, I close some relais and the
trigger-event occurs.
The MDPA displays the data and till now everything is fine.
But I dont get the MDPA to send me the data with the I/O-driver.
I can`t use the panel-driver because not every setting can be stored before
the measurement and
due to these settings, which default settings are different then the ones I
need for the measurement,
the MDPA loses the data I want to have.
Can somebody tell me how to get the waveform-data out of the MDPA into my
PC with the I/O-driver?
Thanks
Steffen
the measurement and
Thanks
Steffen
