Hi All
Does anyone know how to call an XL macro from vee.
I am sending data to an xl template i have created, which has macros stored
in it. Once my data transfer is complete, i want to make a call to the XL
spreadsheet and call a macro which then performs various calculations on the
data.
P.S Also any one know how to loop an int32 dialog box. SO that if the user
presses cancel it will loop and repeat the question??
Cheers
Amrik
data.
Cheers
Amrik
i am using the VEE to do signal processing. after the fft, i want to
diplay it. usually the datas are in array, but every element is complex.
how to display the frequecy and how to scale the diaplay?
any reply is welcome. thanks a lot.
_________________________________________________________________
MSN Explorer: http://explorer.msn.com/lccn
