vrf DLL problem
Question asked by ChrisPotter on Jul 28, 2004
Dear Barrie,
Having been at the same task this week, I suspect the following (but send me
the header file if I've guessed wrongly...)
1) Name-mangling - put the following around your exported function names in
the header you use to compile it with:
extern "C" {
2) some types aren't understood by VEE although they are valid C, so you
might need to alter your function headers (8-bit integer types are a problem
I think, I stick to int and double these days)
3) calling conventions - STDCALL, CDECL and all that - is VEE assuming the
wrong one?
best regards,
Chris Potter
Aphena Ltd.,
10, Teversham Road, Fulbourn,
Cambridge, U.K. CB1 5EB
Tel +44 1223 700499   Fax +44 870 7061487
Mobile +44 7946 354276
http://www.aphena.com
http://www.softplot.com
** Aphena is the new company brand name for software previously sold by P&H
Technology Consultants
Sent: 29 July 2004 02:15 PM
To: VRF
Subject: [vrf] DLL problem
Hi Folks,
Having given up on my "is program running" problem I have moved right
along to another difficulity. I have a simple DLL written in C++ and I
wish to use the function it contains from within Vee.  The DLL's library
and definition file load properly in C++ and the function works
correctly.  The library also appears to load corrctly in Vee and the
function is listed under the Program Explorer's Compiled Functions (with
a yellow f(x) icon).  Clicking on the icon brings up the expected "what
do you want to do" box and I can generate a "call" or a "formula call".
However, when I run the program I get an error message stating "Function
is not loadable" (error 604).  What have I missed?
Barrie
whoi
You are currently subscribed to vrf as: chris.potter@aphena.com
