Hi
I response myself... if I use :
ExcelApp.DisplayFullScreen=True;
ExcelApp.DisplayFullScreen=False;
and it works .
> Hi,
> The excel process has some strings attached and stays open. This is a
> problem related to Excel, not VEE. To get rid of this, toggle 'Disable
> Debug
> Features' in default preferences and you oughta get rid of excel when
> calling quit(). Cons: you cannot debug then though...Kill the process with
> task manager, that worked for me.
> BR,
> -Antti
>> -----Original Message-----
>> From: pvergara@tqr.biz [mailto:pvergara@tqr.biz]
>> Sent: 7. lokakuuta 2004 14:11
>> To: VRF
>> Subject: [vrf] ExcelApp.Visible=TRUE
>> Hi to all.
>> I am making a program with VEE that stores certain data in a
>> spreadsheet
>> Excel. In this program when it is pressed a button I put a
>> code that opens
>> the spreadsheet and is showing the results that are stored (I only use
>> "ExcellApp.Visible=True" in this code).
>> Now my problem comes when the Excel application is closed and
>> it is tried
>> to return to open since using. The application show excel but
>> the data are
>> not seen since the spreadsheet like is blocked.
>> Some idea what is the problem?
> Please note: This e-mail may contain privileged and confidential
> information
> and is intended solely for the addressee. If you are not the intended
> recipient or an employee responsible for delivering this message to the
> intended recipient, you are hereby notified that any review, publication,
> dissemination, distribution, copying or use of the information in this
> message is strictly prohibited. If you have received this e-mail by error,
> please notify the sender immediately by replying to the message and
> subsequently delete it from your system.
> E-mail is susceptible to data corruption, interception, unauthorized
> amendment, tampering and viruses. We only send and receive e-mail messages
> on the basis that we are not liable for any such corruption, interception,
> amendment, tampering, viruses, any other reprehensible acts or any
> consequences of the aforementioned.
> You are currently subscribed to vrf as: pvergara@tqr.biz
and it works .
> Hi,
> Debug
> BR,
> -Antti
>> To: VRF
>> Hi to all.
>> spreadsheet
>> code that opens
>> it is tried
>> the data are
> information
I am making a program with VEE that stores certain data in a spreadsheet
Excel. In this program when it is pressed a button I put a code that opens
Now my problem comes when the Excel application is closed and it is tried
to return to open since using. The application show excel but the data are
