I feel glad to know this problem has been solved.
This is just for your information.
VEE automatically detects a serial port by "Find Instruments" in
the Instrument Manager. However, VEE does not automatically
detect a instrument connected to the serial port.
FUKUI Yutaka
> Dwayne Rowland wrote:
> Yes I can talk to the scope with visa but not Vee. Will Vee normally
> automatically detect a serial instrument? Because if I try to "Find
> Instruments" in the Instrument Manager, Vee finds all of the GPIB
> instruments but does not find the serial instrument.
> Just to clarify, the error I get says " Serial Interface, at 1, is not
> configured for this system. Error number 801.
> From: Rufus Warren [mailto:rwarren@amti.net]
> Sent: Tuesday, August 03, 2004 8:12 AM
> To: Dwayne Rowland; 'VRF'
> Subject: RE: [vrf] RE: Serial port communication
> What's happening here? I suggest look at the basic needs.
> Assuming all plugged correctly and power on ok.
> 1st the com port is active in windows.
> 2nd it is active(same settings) in IO config
> 3rd it is active(same settings) within VEE IO | Instrument manager
> 4th the instrument is talking same protocol as above
> 5th the instrument is set to use the com port
> Then you send and identify *idn? and this works at visa but not at
> vee?
> Is this what you are saying?
> Whoa, we got hebejeebees.
> From: Dwayne Rowland [mailto:drowland@rfmd.com]
> Sent: Tuesday, August 03, 2004 7:58 AM
> To: VRF
> Subject: [vrf] RE: Serial port communication
> The *idn? command works fine when sent to the instrument using VISA
> assistant but when I try it from VEE I am now getting an error that
> says "Instrument is not configured properly", all of the settings on
> the scope match the settings in VEE.
> From: Ron Pratt [mailto:RPratt@symmetricom.com]
> Sent: Monday, August 02, 2004 7:37 PM
> To: VRF
> One quick test is to try a terminal emulator to verify communications
> between computer and scope. This would 1/2 split the problem. The
> *idn? command should yield a response on the terminal screen.
> -----Original Message-----
> Sent: Monday, August 02, 2004 12:29 PM
> To: VRF
> I have defined the IO as RS232. When I send the *idn?
> command, or any other command for that matter, nothing
> happens. It's like the command is not getting sent to the
> instrument.
> Sent: Monday, August 02, 2004 3:17 PM
> To: VRF
> Have you defined the IO for the scope to be RS232 ? If you
> send a query like *idn? do you get a timeout msg? A timeout
> suggests either the scope is not configured for serial comm
> or the Tx Rx lines are swapped.
> Sent: Monday, August 02, 2004 12:10 PM
> To: VRF
> Subject: [vrf] Serial port communication
> Greetings,
> I need to control an Agilent 54621D oscilloscope
> via RS232. Can anyone give me any insight to how
> this is accomplished. I thought it was as simple
> as adding a serial instrument in the I/O config,
> making sure the Baud Rate and handshake are the
> same on the instrument and in Vee, and then off
> you go. However, it seems I am missing something
> because Vee will not send any commands to the
> instrument. It's like it doesn't even know the
> instrument is there. I am using the correct cable.
> Any help will be greatly appreciated,
> Dwayne
> You are currently subscribed to vrf as:
> To subscribe send a blank email to
> "join-vrf@it.lists.it.agilent.com".
> To send messages to this mailing list, email
> "vrf@agilent.com".
> If you need help with the mailing list send a
> message to "owner-vrf@it.lists.it.agilent.com".
> You are currently subscribed to vrf as: drowland@rfmd.com
> "vrf@agilent.com".
> "owner-vrf@it.lists.it.agilent.com". ---
> "vrf@agilent.com".
> You are currently subscribed to vrf as: rwarren@amti.net
> You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com
* $BJ!0f!!K-!J (BFUKUI Yutaka)
* E-Mail: fukui.yutaka@jp.fujitsu.com
* $BIY;NDL3t<02q<R!!@n:j9)>l (B
* $B$b$N$E$/$j?d?JKIt!&@8;:5;=Q3+H/E}3gIt!K7WB,@_Hw3+H/It (B
* $B7WB,@_Hw3+H/It (BHomePage http://www.psl.fujitsu.co.jp/htd2/ksk/
* $B@n:j;TCf866h>e>.EDCf#4 (B- $B#1 (B- $B#1!!M9JXHV9f!' (B211-8588
* TEL $B!!30@~ (B 044-754-3657, $B!!Fb@~ (B 711-3-1966,7
* FAX $B!!30@~ (B 044-754-3509, $B!!Fb@~ (B 711-3-5359
FUKUI Yutaka
> vee?
> To: VRF
> To: VRF
> To: VRF
> instrument.
> To: VRF
> To: VRF
> Greetings,
> Dwayne
> "vrf@agilent.com".
> "vrf@agilent.com".
> "vrf@agilent.com".
" to "
" (which uses a carriage return at the end of the line instead of a line feed). 3. Direct I/O tab --> Array separator from "," to " ".</SPAN></FONT></DIV><DIV><FONT face="MS Sans Serif" color=#800080 size=2><SPAN class=896420312-03082004></SPAN></FONT> </DIV><DIV><FONT face="MS Sans Serif" color=#800080 size=2><SPAN class=896420312-03082004>Hope this helps</SPAN></FONT></DIV><DIV><FONT face="MS Sans Serif" color=#800080 size=2><SPAN class=896420312-03082004></SPAN></FONT> </DIV><DIV><FONT face="MS Sans Serif" color=#800080 size=2><SPAN class=896420312-03082004><P><B><FONT face=Verdana color=#800080 size=2>Lenny Hill</FONT></B> <BR><FONT face=Verdana color=#800080 size=2>Manufacturing / Test Engineer - New Product Introduction</FONT> <BR><FONT face=Verdana color=#800080 size=2>Worldwide Operations</FONT> </P></SPAN></FONT></DIV><BLOCKQUOTE> <DIV class=OutlookMessageHeader dir=ltr align=left><FONT face=Tahoma size=2>-----Original Message-----<BR><B>From:</B> Dwayne Rowland [mailto:drowland@rfmd.com]<BR><B>Sent:</B> Tuesday, August 03, 2004 6:58 AM<BR><B>To:</B> VRF<BR><B>Subject:</B> [vrf] RE: Serial port communication<BR><BR></FONT></DIV> <DIV dir=ltr align=left><SPAN class=474165111-03082004></SPAN><FONT face=Arial><FONT color=#0000ff><FONT size=2>T<SPAN class=474165111-03082004>he *idn? command works fine when sent to the instrument using VISA assistant but when I try it from VEE I am now getting an error that says "Instrument is not configured properly", all of the settings on the scope match the settings in VEE.</SPAN></FONT></FONT></FONT></DIV> <DIV dir=ltr align=left><BR></DIV> <DIV class=OutlookMessageHeader lang=en-us dir=ltr align=left> <HR tabIndex=-1> <FONT face=Tahoma size=2><B>From:</B> Ron Pratt [mailto:RPratt@symmetricom.com] <BR><B>Sent:</B> Monday, August 02, 2004 7:37 PM<BR><B>To:</B> VRF<BR><B>Subject:</B> [vrf] RE: Serial port communication<BR></FONT><BR></DIV> <DIV></DIV> <DIV><FONT face=Arial color=#0000ff size=2><SPAN class=334043623-02082004>One quick test is to try a terminal emulator to verify communications between computer and scope. This would 1/2 split the problem. The *idn? command should yield a response on the terminal screen.</SPAN></FONT></DIV> <BLOCKQUOTE> <DIV class=OutlookMessageHeader dir=ltr align=left><FONT face=Tahoma size=2>-----Original Message-----<BR><B>From:</B> Dwayne Rowland [mailto:drowland@rfmd.com]<BR><B>Sent:</B> Monday, August 02, 2004 12:29 PM<BR><B>To:</B> VRF<BR><B>Subject:</B> [vrf] RE: Serial port communication<BR><BR></FONT></DIV> <DIV dir=ltr align=left><SPAN class=788342719-02082004><FONT face=Arial color=#0000ff size=2>I have defined the IO as RS232. When I send the *idn? command, or any other command for that matter, nothing happens. It's like the command is not getting sent to the instrument.</FONT></SPAN></DIV><BR> <DIV class=OutlookMessageHeader lang=en-us dir=ltr align=left> <HR tabIndex=-1> <FONT face=Tahoma size=2><B>From:</B> Ron Pratt [mailto:RPratt@symmetricom.com] <BR><B>Sent:</B> Monday, August 02, 2004 3:17 PM<BR><B>To:</B> VRF<BR><B>Subject:</B> [vrf] RE: Serial port communication<BR></FONT><BR></DIV> <DIV></DIV> <DIV><FONT face=Arial color=#0000ff size=2><SPAN class=051561519-02082004>Have you defined the IO for the scope to be RS232 ? If you send a query like *idn? do you get a timeout msg? A timeout suggests either the scope is not configured for serial comm or the Tx Rx lines are swapped.</SPAN></FONT></DIV> <BLOCKQUOTE> <DIV class=OutlookMessageHeader dir=ltr align=left><FONT face=Tahoma size=2>-----Original Message-----<BR><B>From:</B> Dwayne Rowland [mailto:drowland@rfmd.com]<BR><B>Sent:</B> Monday, August 02, 2004 12:10 PM<BR><B>To:</B> VRF<BR><B>Subject:</B> [vrf] Serial port communication<BR><BR></FONT></DIV><!-- Converted from text/rtf format --> <P><FONT face=Arial size=2>Greetings,</FONT> </P> <P><FONT face=Arial size=2>I need to control an Agilent 54621D oscilloscope via RS232. Can anyone give me any insight to how this is accomplished. I thought it was as simple as adding a serial instrument in the I/O config, making sure the Baud Rate and handshake are the same on the instrument and in Vee, and then off you go. However, it seems I am missing something because Vee will not send any commands to the instrument. It's like it doesn't even know the instrument is there. I am using the correct cable.</FONT></P> <P><FONT face=Arial size=2>Any help will be greatly appreciated,</FONT> </P> <P><FONT face=Arial size=2>Dwayne</FONT> </P>---<BR>You are currently subscribed to vrf as: RPratt@symmetricom.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". </BLOCKQUOTE>---<BR>You are currently subscribed to vrf as: drowland@rfmd.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". ---<BR>You are currently subscribed to vrf as: RPratt@symmetricom.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". </BLOCKQUOTE>---<BR>You are currently subscribed to vrf as: drowland@rfmd.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". ---<BR>You are currently subscribed to vrf as: lenny.Hill@adc.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". </BLOCKQUOTE>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></HTML>
array(A[0,0]/B[0], A[0,1]/B[1}... A[3,3]/B[3] ???
Can you do that, divide a 4x4 by a 4x1???? How do you get the inverse of B,
doesn't B need to be square?
rufus
From: Susanne Ejby Sndergaard Jrgensen [mailto:sej@rtx.dk]
Sent: Tuesday, August 03, 2004 10:18 AM
To: VRF
Subject: [vrf] Matrices and matDivide
I am going to use gauss elemination a two matrices (MATLAB expression X =
AB)
I have tried the built-in function MatDivide and a MATLAB Script. The input
is A(4x4 matrix) and B(4x1 matrix) and the output is X. But I can't get any
of the two methods to work.
A = [262144, 4096, 64, 1; 166375, 3025, 55, 1; 97336, 2116, 46, 1; 46656,
1296, 36, 1]
B = [70; 60; 50; 40]
X = AB
Is there anyone who has some experience in using math at matrices in Agilent
Vee?
Best regards,
Susanne Jrgensen
You are currently subscribed to vrf as: rwarren@amti.net To subscribe send a
Oh, dude! I am pathetically poor. We're talking about *way* below poverty
here. The hardware I own is what I can scrum together out of other people's
discarded junque. My most recent box is a P3 733 and I only got that because
I traded some work for a cheap IBM refurb.
It's just that I would hate to see the death of such useful interfaces.
After all, anybody can build a serial or parallel interface (even I can do
that), but how many people can build a USB interface?
-SHAWN-
PS - to all those who have mentioned offers, no, I haven't forgotten nor am
I snubbing anybody, I just want to stick to my end-of-summer deadline for
reevaluation. Even though it's starting to look like that's a really big
mistake
You said, " I sincerely hope we never see the death of the simple PC
serial and parallel ports."
What model PCs do you have living at your place? All of mine contain
both a parallel port and serial port, this one has two USB 1.1 ports,
on its back. The legacy IO ports, parallel and serial are being
discontinued in favor of just USB. Of course I'd have to bug Dell
about it, since I now specify all Dell machines for my clients.
Gregg C Levine hansolofalcon@worldnet.att.net
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke." Obi-Wan Kenobi
> From: Shawn Fessenden [mailto:shawn@testech-ltd.com]
> Sent: Tuesday, August 03, 2004 3:09 PM
> To: VRF
> > All is now good
> I sympathize! The first time I tried to do serial with VEE all I
could think was, "this
> is so gosh blessed simple... why won't it work?". I imagine that I/O
simplification is
> relatively high on the list over there, and in spite of the fact
that complex I/O is
> pretty much a snap now serial and parallel I/O improvements will be
seen in the
> future. They are both still really quick and easy ways to get things
off the ground (or
> at least they should be!). I sincerely hope we never see the death
of the simple PC
> -SHAWN-
laptop (for work) a few weeks ago, and was alarmed that the serial port was
not available without a docking station. PCMCIA serial cards were not
avaiable, but for $19 I got a USB to serial converter/cable - and it looked
JUST like a COM port to IO Config and to VEE.
-- Kathy
Kathy Wright
kathy_wright_ca@yahoo.com
----- Original Message -----
From: "Gregg C Levine" <hansolofalcon@worldnet.att.net>
To: "VRF" <vrf@agilent.com>
Sent: Tuesday, August 03, 2004 1:19 PM
Hello from Gregg C Levine
> To: VRF
> > All is now good
simplification is
that complex I/O is
seen in the
off the ground (or
of the simple PC
> -SHAWN-
You are currently subscribed to vrf as: kathy_wright_ca@yahoo.com
That's the way the laptop crowd is moving towards. I don't know if it
will effect the desk computer market though.
> From: Kathy Wright [mailto:kathy_wright_ca@yahoo.com]
> Sent: Wednesday, August 04, 2004 1:21 AM
> To: Gregg C Levine; VRF
> Subject: Re: [vrf] RE: Serial port communication
> I pretty much assumed I would always have a serial port, but got a
new
port was
not
it looked
> -- Kathy
> Kathy Wright
ports,
> > To: VRF
> > > All is now good
I/O
> simplification is
> that complex I/O is
be
> seen in the
things
> off the ground (or
> of the simple PC
> > -SHAWN-
>> a new laptop a few weeks ago, and was alarmed that the serial
>> port was not available without a docking station.
Most likely it will. In one word "cheaper." My home computer can
get along just fine without a serial port. But I need USB. If other
home users are like that (not needing serial) the manufacturers can save
a few $$$ by deleteing serial - and those that need serial can get the
USB adaptor. Economics says serial will go away (as a standard computer
port, maybe not as an available adaptor for instruments.)
Les Hammer
