"Alexander Poulikakos (KI/EAB) <alexander.poulikakos@ericsson.com> wrote:
> Hi
> Is there any way to set record fields names programicaly
> in VEE? This had me going crazy for a while, As I really
> wanted to set record field names dynamicaly.
> I found out a way to do it, but it's kind of dirty. Is there any better way?
> See attached VEE 6.03 program.
The std method is to create a dummy record then change the name
of the field as needed. This looks like what you have done.
You can also just create a record in the first place
with a "to String" but then that becomes fragile since the
syntax could change slightly and the record would be invalid.
Stan
> Hi
Stan
