vrf GPIB over LAN
Question asked by VRFuser on Jul 30, 2004
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><TITLE>GPIB over LAN</TITLE><META http-equiv=Content-Type content="text/html; charset=iso-8859-1"><META content="MSHTML 6.00.2800.1400" name=GENERATOR></HEAD><BODY><DIV><FONT face=Arial><FONT size=2><SPAN class=380222323-30072004>>> I</SPAN> have been trying to use the equipment connected to a NI GPIB card in a remote PC over a network.  The remote system has a SA and O'scope connected over GPIB.  I have Agilent VISA as the secondary to NI.  </FONT></FONT><FONT face=Tahoma><BR><SPAN class=380222323-30072004><FONT face=Arial color=#0000ff size=2> </FONT></SPAN></FONT></DIV><DIV><FONT face=Tahoma><SPAN class=380222323-30072004><FONT face=Arial color=#0000ff size=2>> </FONT></SPAN></FONT><SPAN class=516253623-28072004><FONT face=Arial color=#0000ff size=2>I am getting the following error when trying to connect to the remote GPIB over LAN (this is seen in the Sicl display on the remote system) :</FONT></SPAN></DIV><BLOCKQUOTE>  <DIV><FONT face=Arial><FONT color=#0000ff><FONT size=2><SPAN   class=516253623-28072004><SPAN class=380222323-30072004>>   </SPAN></SPAN><SPAN class=516253623-28072004>SICLLAND [Time and Date here]:   Client - {process 0 connected to serve process 792<SPAN   class=380222323-30072004>     ... </SPAN></SPAN></FONT></FONT></FONT></DIV>  <DIV><SPAN class=516253623-28072004><FONT face=Arial color=#0000ff   size=2></FONT></SPAN> </DIV>  <DIV><SPAN class=516253623-28072004><FONT face=Arial color=#0000ff   size=2><SPAN class=380222323-30072004> </SPAN></FONT></SPAN></DIV>  <DIV><SPAN class=516253623-28072004><FONT face=Arial color=#0000ff   size=2><SPAN class=380222323-30072004>Some additional   questions:</SPAN></FONT></SPAN></DIV>  <DIV><SPAN class=516253623-28072004><FONT face=Arial color=#0000ff   size=2><SPAN class=380222323-30072004></SPAN></FONT></SPAN> </DIV>  <DIV><SPAN class=516253623-28072004><FONT face=Arial color=#0000ff   size=2><SPAN class=380222323-30072004>1) Can you talk to the instrument with   Agilent VISA Assistant running on the remote (the one with the   scope) system?</SPAN></FONT></SPAN></DIV>  <DIV><SPAN class=516253623-28072004><FONT face=Arial color=#0000ff   size=2><SPAN class=380222323-30072004>1a) If not, Did you (either install   Agilent VISA or re-run Agilent I/O config) AFTER (you installed the NI-GPIB   and configured it with NI-VISA)? </SPAN></FONT></SPAN></DIV>  <DIV><SPAN class=516253623-28072004><FONT face=Arial color=#0000ff   size=2><SPAN class=380222323-30072004>1b) If you can connect on the remote   system, have you run Agilent I/O config on the local AFTER you got the remote   working?</SPAN></FONT></SPAN></DIV>  <DIV><SPAN class=516253623-28072004><FONT face=Arial color=#0000ff   size=2><SPAN class=380222323-30072004></SPAN></FONT></SPAN> </DIV>  <DIV><SPAN class=516253623-28072004><FONT face=Arial color=#0000ff   size=2><SPAN class=380222323-30072004>  <P><FONT size=2>Les Hammer<BR>Partner<BR>Complete Test<BR>720 SW 14th   St.<BR>Loveland, CO.  80537<BR>Les.Hammer@CompleteTest.com   </FONT></P></SPAN></FONT></SPAN></DIV></BLOCKQUOTE>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list,  email "vrf@agilent.com".  <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></HTML>
