I pretty much assumed I would always have a serial port, but got a new
laptop (for work) a few weeks ago, and was alarmed that the serial port was
not available without a docking station. PCMCIA serial cards were not
avaiable, but for $19 I got a USB to serial converter/cable - and it looked
JUST like a COM port to IO Config and to VEE.
-- Kathy
Kathy Wright
kathy_wright_ca@yahoo.com
----- Original Message -----
From: "Gregg C Levine" <hansolofalcon@worldnet.att.net>
To: "VRF" <vrf@agilent.com>
Sent: Tuesday, August 03, 2004 1:19 PM
Subject: [vrf] RE: Serial port communication
Hello from Gregg C Levine
You said, " I sincerely hope we never see the death of the simple PC
serial and parallel ports."
What model PCs do you have living at your place? All of mine contain
both a parallel port and serial port, this one has two USB 1.1 ports,
on its back. The legacy IO ports, parallel and serial are being
discontinued in favor of just USB. Of course I'd have to bug Dell
about it, since I now specify all Dell machines for my clients.
Gregg C Levine hansolofalcon@worldnet.att.net
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke." Obi-Wan Kenobi
> -----Original Message-----
> From: Shawn Fessenden [mailto:shawn@testech-ltd.com]
> Sent: Tuesday, August 03, 2004 3:09 PM
> To: VRF
> > All is now good
> I sympathize! The first time I tried to do serial with VEE all I
could think was, "this
> is so gosh blessed simple... why won't it work?". I imagine that I/O
simplification is
> relatively high on the list over there, and in spite of the fact
that complex I/O is
> pretty much a snap now serial and parallel I/O improvements will be
seen in the
> future. They are both still really quick and easy ways to get things
off the ground (or
> at least they should be!). I sincerely hope we never see the death
of the simple PC
> -SHAWN-
You are currently subscribed to vrf as: kathy_wright_ca@yahoo.com
-- Kathy
Kathy Wright
> To: VRF
> > All is now good
simplification is
that complex I/O is
seen in the
off the ground (or
of the simple PC
> -SHAWN-
