Hello Yong,
you do misunderstand something...this answer belongs to a Screencapture from
the PC-Display.
Regarding your question i just can say:
Have a look at www.my-vee.de under downloads.
There is a sample program available which shows how to communicate to a
Spectrum-Analyzer.
It is using Direct-IO Commands. Normally you read out the datas from the
Spectrumanalyzer and make your own diagram then. ( Which can be the same as
your SPek-Screen of course)
I do not know if your Spectrumanalyzer do have an easier way of built in
function to dump the screen, sorry.
There are also tons of examples available in the example folder of VEE7 !
best regards,
detlef
Von: KWANG,YONG (A-Singapore,ex1) [mailto:yong_kwang@agilent.com]
Gesendet: 01 July 2004 08:42
An: VRF
Betreff: [vrf] RE: AW: RE: VEEs are not found /Screenshot
But the image/screen is on the instruments so how do we program using VEE to
capture the image from the display of the E4406A to the VEE program,
Benchlink software provide the Image function which we can capture the image
from the instrument after we made a measurement.
Warm Regards,
Kwang Yong
From: Baranski, Detlef [mailto:Detlef.Baranski@PILKINGTON.de]
Sent: Thursday, July 01, 2004 2:36 PM
Subject: [vrf] AW: RE: VEEs are not found /Screenshot
Incidentally how did you capture the screenshot?
Gregg C Levine hansolofalcon@worldnet.att.net
hello Greg,
making a screenshot is a built in windows function...but it is not well
known ;-(
Press the Print ( Or Druck ) button. That captures the actual sceeen.
Then go to a paint program like MS-Paint and insert it via ctrl- V or via
insert menu.
If you need better capture facility there are some extra programs available
like Hypersnap DX.
Best regards,
detlef
This message and any attachments are confidential, for the exclusive use of
the addressee and may be legally privileged. Any other distribution, use or
reproduction is unauthorised and prohibited. If you have received this
message in error, please notify the sender immediately and delete the
message from your system.
Visit our internet site at http://www.pilkington.com
the PC-Display.
Spectrum-Analyzer.
best regards,
detlef
An: VRF
Warm Regards,
Kwang Yong
hello Greg,
known ;-(
insert menu.
like Hypersnap DX.
Best regards,
detlef
