<html><font size=3>Will VEE 7's "System -->Send Mail" option allowyou to send attachments with the email? If not, is there a way to do sowith VEE 7?
Thank you.
Roger
At 09:31 AM 7/14/2004 -0600, COLASUONNO,KEN (A-Loveland,ex1) wrote:
<blockquote type=cite cite>If you have VEE 7, try the System --> SendMail menu pick. Very easy.
Earlier versions of VEE have an example: Help menu pick --> Open
Example... dialog --> Lib directory --> SMTPMail.vee
Either of these expect you to connect to an SMTP server. Askyour
sys-admin what machine has open SMTP ports on it.
Ken
From: Johns, Paul (EU-SES)[<a href="mailto:Paul.Johns@eu.sony.com" eudora="autourl">mailto:Paul.Johns@eu.sony.com</a>]
Sent: Wednesday, July 14, 2004 7:14 AM
To: VRF
Subject: [vrf] email from VEE
Dear all,
Does anybody have a working example of sending an email from VEE,
without
Outlook asking if it is ok to send the mail.
Thanks
Paul Johns
The information contained in this message or any of its attachmentsmay
be confidential and is intended for the exclusive use of the
addressee(s). Any disclosure, reproduction, distribution or other
dissemination or use of this communication is strictly prohibited
without the express permission of the sender. The views expressed in
this email are those of the individual and not necessarily those ofSony
or Sony affiliated companies. Sony email is for business use only.
This mail or any response may be monitored by Sony United Kingdom
Limited. (6)
You are currently subscribed to vrf as: ken_colasuonno@agilent.com
To subscribe send a blank email to"join-vrf@it.lists.it.agilent.com".
To send messages to this mailing list, email"vrf@agilent.com".
You are currently subscribed to vrf as: rogerv@cisco.com
To unsubscribe send a blank email to"leave-vrf@it.lists.it.agilent.com".
If you need help with the mailing list send a message to"owner-vrf@it.lists.it.agilent.com". </font></blockquote>
---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</html>
Thank you.
Roger
Ken
To: VRF
Dear all,
without
Thanks
Paul Johns
Limited. (6)
When your "To File Object" seems to be not activated, add proper
sequence control to the sequence input pin of your "To File Object".
I experienced the same kind of troubles around the "To File Object".
FUKUI Yutaka
jdunca1 wrote:
> Hi I have a program that reads what is coming into my oscilliscope. I want to
> save the data to a file and i have tried using a to file and sending it to
> excel but no data shows up. I need to be able to look over the data later
> after the test is run. IF anyone can help i would greatly appreciate it.
> Thank
> Jason Duncan
> You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com
* $BJ!0f!!K-!J (BFUKUI Yutaka)
* E-Mail: fukui.yutaka@jp.fujitsu.com
* $BIY;NDL3t<02q<R!!@n:j9)>l (B
* $B$b$N$E$/$j?d?JKIt!&@8;:5;=Q3+H/E}3gIt!K7WB,@_Hw3+H/It (B
* $B7WB,@_Hw3+H/It (BHomePage http://www.psl.fujitsu.co.jp/htd2/ksk/
* $B@n:j;TCf866h>e>.EDCf#4 (B- $B#1 (B- $B#1!!M9JXHV9f!' (B211-8588
* TEL $B!!30@~ (B 044-754-3657, $B!!Fb@~ (B 711-3-1966,7
* FAX $B!!30@~ (B 044-754-3509, $B!!Fb@~ (B 711-3-5359
