<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><META http-equiv=Content-Type content="text/html; charset=iso-8859-1"><META content="MSHTML 6.00.2800.1106" name=GENERATOR><STYLE></STYLE></HEAD><BODY bgColor=#ffffff><DIV><FONT face=Arial size=2>IT WORKS !!</FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2>Thank you Stefan for the German screenshots. Though they are not WIN98, I could make it: "Ordneroptionen..." I found under "Ansicht" in the menu-bar of "Arbeitsplatz". I still don't know the translation into "original" English of those terms!</FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2>Thanks to the others (and Shawn), who gave the same solution: |space> "%1".</FONT></DIV><DIV><FONT face=Arial size=2>I thought, DOS was out of fashion, it is not ! (I used these variables a long time ago, when I wrote elaborate batch-files.)</FONT></DIV><DIV> </DIV><DIV><FONT face=Arial size=2>Concerning the screenshots:</FONT></DIV><DIV><FONT face=Arial size=2>I use "jascap32.exe", an old relict of the days of Windows 1.3, which still works under WIN98(and up ?).</FONT></DIV><DIV><FONT face=Arial size=2>I learned from your messages, that "new Windows" has this feature again as in the old DOS-days: press PRINT-button (or DRUCK in German).</FONT></DIV><DIV><FONT face=Arial size=2>So it seems to me, that I must install a newer Windows. (I'd like to install my version of VEE7, but WIN98 1st doesn't accept it !). But it's so horrible, to be busy one week installing all that programs and reconstructing the old known desktop!!</FONT></DIV><DIV><FONT face=Arial size=2>--> This is MY problem !! </FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2>Thanks again and have a nice time working with VEE</FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2>Peter</FONT></DIV><DIV><A href="http://www.pcmess.com"><FONT face=Arial size=2>www.pcmess.com</FONT></A><BR><FONT face=Arial size=2>Birkenweg 8<BR>D-87677 Stoettwang<BR>Tel: +498345482</FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></HTML>
> change what in the registry or elsewhere to make it
> work as it should. Maybe Shawn knows ?!
>From Explorer, select Tools->Folder Options. Click the "File Types" tab. It
will probably take a while to analyze all the types listed. When it gets
done, scroll down to VEE in the left hand column. If it's there, select it
and click Edit. In the dialog that pops up, Look at the "Actions" list.
There will be something like Edit, Start, Run or Open. The highlighted one
should be Open. Select it and click "Edit". In the "Application used to
perform action:" edit box you should see the path to VEE Pro.
If VEE File isn't listed in the "Registered file types" list, click "New
Type...". Description should be "VEE File", Associated extension should be
".vee". In the "Actions" list, Click "New...". In the "Action" edit box,
type in "Open". In the "Application used to perform action" edit box, enter
the path to VEE Pro or click "Browse" and navigate to VEE Pro.
That should do it.
-SHAWN-
There is a double quote missing somewhere along the line. Spaces are evil. I
know MS says they're not, but it's a lie. They are.
The "Application used to perform action" must read as such:
"c:Program FilesAgilentVEE Pro 6.2vee.exe" "%1"
Naturally the path to VEE has to match your installation. The quotes around
the second part have been lost.
-SHAWN-
Hi Peter...
<Shawn>
</Shawn>
Having followed Shawn's instructions, you will notice that the path to VEE
Pro is followed by a space, then the characters: %1
........make sure that these charactures are enclosed in quotes, like this:
"%1"
Cheers
Paul F.
"P.Weber-pcmess" To: VRF <vrf@agilent.com>
<p.weber@pcmess.de> cc:
30/06/04 Subject: [vrf] VEEs are not found
16:50
Please respond to
"P.Weber-pcmess"
Stationery name:-Untitled-
Hello again,
here is the message VEE sent to me, when I was trying to open the attached
VEE from Kevin.Hasselquist@nokia.com of 26.6.04: Coloralarm2.vee by
"double-click":
The real path should have read: C:WINDOWSTemporary Internet Files...,
which sent me to the idea to omit the spaces: "nuts".
This may explain, what I mean with "omitting the header of the path"(the
underlined has been omitted). Replacing the spaces by other characters
leads to similar effects:
Part of the leading path-sequence is left out.
Quite a strange behaviour of "old WIN98" (?!)
Peter
www.pcmess.com
Birkenweg 8
D-87677 Stoettwang
Tel: +498345482
You are currently subscribed to vrf as: Paul.Fowler@raytheon.co.uk
"owner-vrf@it.lists.it.agilent.com". ---
Hi Peter...
<Shawn>
</Shawn>
"%1"
Cheers
Paul F.
16:50
Please respond to
"P.Weber-pcmess"
Hello again,
"double-click":
Peter
www.pcmess.com
Birkenweg 8
D-87677 Stoettwang
Tel: +498345482
http://promotions.yahoo.com/new_mail
Any 9x (including ME) is DOS based. That's why I call 'em "fake". It's still
a problem for any NT too though. The command processor uses a space for a
delimiter and hence all the problems.
-SHAWN-
