Hi Mark,
thats the best way. We do that all the time and it is the only help in
several Memory leak problems VEE has (there are several). If you unload the
library the memory goes back to normal.
Very best regards
Somatec B. Aufenanger & M. Bernhardt
Jagdweg 7a
D-82041 Deisenhofen
Telefon : (089) 613 984 91
Fax. : (089) 613 981 23
Email : mailto:Aufenanger@somatec.de
homepage : http://www.somatec.com/
Von: Goldberg, Mark [mailto:Mark.Goldberg@ATK.COM]
Gesendet: Montag, 28. Juni 2004 18:17
An: VRF
Betreff: [vrf] RE: Vee - Memory "Leak"
As George I didn't have time to test this but you might try putting the
allocation into an imported library and when you are done, delete the
library, which should hopefully delete the memory allocation.
Good Luck,
Mark
Sent: Monday, June 28, 2004 8:35 AM
To: VRF
Subject: [vrf] RE: Vee - Memory "Leak"
Try to put the allocation object into a user object (or function).
I suppose that the allocated memory (that should be the data at the
alloc-out-pin) is freed when the user object/function terminates.
I didn't test it... just a guess
Georg
[mailto:sascha_spangenberg@agilent.com]
Sent: Monday, June 28, 2004 4:47 PM
To: VRF
<snip>
> The initial Alloc is still there.
Yes - that seems to make sense but how can I prevent this?
I.e. if I only want to allocate ONE array of the appropriate size
and assign it to a variable.. I never intended to do a "copy" operation.
Alternatively how do I delete the initial array once I have copied
it to a variable?
Sascha
> Les Hammer
> Partner
> Complete Test
> 720 SW 14th St.
> Loveland, CO. 80537
> Les.Hammer@CompleteTest.com
You are currently subscribed to vrf as: g.nied@gn-software.de
You are currently subscribed to vrf as: Mark.Goldberg@ATK.COM
You are currently subscribed to vrf as: Aufenanger@somatec.de
Very best regards
Jagdweg 7a
D-82041 Deisenhofen
An: VRF
Good Luck,
Mark
To: VRF
Georg
To: VRF
<snip>
it to a variable?
Sascha
> Les Hammer
> Partner
> Complete Test
> 720 SW 14th St.
> Loveland, CO. 80537
