I'm in need of making a routine that shows on the screen the yield of tested boards. To improve the efficiency of my fixtures that would help me a lot.
Somebody already did something like that or have any idea to help me???
In this same routine could show me my top offenders of failures.
Thank you and I look forward to returning.
would you look at the attached picture to see if this is something that you want?
The screen capture shows the "first PASS yield" (FPY) for the product tested on the Agilent i3070 ICT system.
Below the FPY is a list of top hitters of probes related to failures detected. We believe that this would help the user identify if probes are causing the current failures due to false rejects.
rgds ... adrianc
