In that (Vee 7) example, writing recipient addresses with an
appropriate separator("," and ";" worked successfully) enabled us
to send email to more than 1 recipient address.
FUKUI Yutaka
"Baranski, Detlef" wrote:
> Here is one example published in the vrf before ( Vee7 ).
> Does it fit your needs ?
> Best regards,
> detlef
> -----Ursprngliche Nachricht-----
> Von: Adalton Alves [mailto:aalves@blt.com.br]
> Gesendet: 24 August 2004 05:12
> An: VRF
> Betreff: [vrf] Sending emails with attached files thru VEE
> Hello VRF !
> Has someone ever experienced to send emails thru VEE? I would appreciate
> comments for two questions:
> 1)How to send attached files?
> 2)How to send email to more than 1 recipient address?
> Here goes the program.
> Thanks and Kind Regards,
> Adalton Alves
> Balda Lumberg Technologies
> *** eSafe scanned this email for malicious content ***
> *** IMPORTANT: Do not open attachments from unrecognized senders ***
> This message and any attachments are confidential, for the exclusive use of
> the addressee and may be legally privileged. Any other distribution, use or
> reproduction is unauthorised and prohibited. If you have received this
> message in error, please notify the sender immediately and delete the
> message from your system.
> Visit our internet site at http://www.pilkington.com
> email_with_attachments.zip Type: Zip Compressed Data (application/x-zip-compressed)
> Encoding: base64
> You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com
> If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
* @LiFUKUI Yutaka)
* E-Mail: fukui.yutaka@jp.fujitsu.com
* x $B (BÊŠ $B%g (B $B%_ (B@H
* Ì‚Ã‚è „i{E $B; (BZpJjvÝ”J
* vݔJHomePage http://www.psl.fujitsu.co.jp/htd2/ksk/
* $B f (Bã ¬cS-P-P@XÖ”Ô F211-8588
* TEL @O 044-754-3657,@ 711-3-1966,7
* FAX @O 044-754-3509,@ 711-3-5359
FUKUI Yutaka
> Best regards,
> detlef
> An: VRF
> Hello VRF !
> Adalton Alves
> Encoding: base64
* @LiFUKUI Yutaka)
