<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1"><TITLE>TCP/IP Communications</TITLE><META content="MSHTML 6.00.2800.1458" name=GENERATOR></HEAD><BODY><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=898542406-12082004>Yes, I have used the the instrument manager.</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=898542406-12082004>From VEE 7 it is possible to control a TCPIP instrument.</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=898542406-12082004></SPAN></FONT> </DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=898542406-12082004>1. Ad the instrument in Agilent IO Libraries Configuration - IO Config</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=898542406-12082004>2. Open the instrument manager in VEE and terminate "Find instruments", the instrument added in IO config should then be found.</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=898542406-12082004>3. Mark the wanted instrument and terminate "Direct I/O", then a Direct I/O component is created and you use it to send fx SCPI commands to the instrument.</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=898542406-12082004></SPAN></FONT> </DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=898542406-12082004>Good luck!</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=898542406-12082004></SPAN></FONT> </DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=898542406-12082004>BR,</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=898542406-12082004>Susanne Jrgensen</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=898542406-12082004></SPAN></FONT> </DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=898542406-12082004></SPAN></FONT> </DIV><BLOCKQUOTE> <DIV class=OutlookMessageHeader dir=ltr align=left><FONT face=Tahoma size=2>-----Original Message-----<BR><B>From:</B> Sparks, Jeffrey [mailto:jspark04@harris.com]<BR><B>Sent:</B> 11. august 2004 19:09<BR><B>Subject:</B> TCP/IP Communications<BR><BR></FONT></DIV> <P><FONT face=Arial size=2>Does anyone have a VEE function that allows writing and reading data to/from an IP address using either the "To/From Socket" object or by setting up an TCPIP instrument in the Instrument Manager?</FONT></P> <P><FONT face=Arial size=2>Thanks,</FONT> <BR><B><FONT face=Arial size=2>Jeff Sparks</FONT></B> <BR><B><FONT face=Arial size=2>Harris Corporation</FONT></B> <BR><B><FONT face=Arial size=2>Palm Bay, FL</FONT></B> <BR><B><FONT face=Arial size=2>321-729-7956</FONT></B> </P><BR></BLOCKQUOTE>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></HTML>
