vrf Directory sort by time
Question asked by mstrutt on Aug 17, 2004
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1"><TITLE>Directory sort by time</TITLE><META content="MSHTML 6.00.2800.1458" name=GENERATOR></HEAD><BODY><DIV><SPAN class=172135614-17082004><FONT face=Arial color=#0000ff size=2>Hi Ross</FONT></SPAN></DIV><DIV><SPAN class=172135614-17082004><FONT face=Arial color=#0000ff size=2>This sounds like hard work.</FONT></SPAN></DIV><DIV><SPAN class=172135614-17082004><FONT face=Arial color=#0000ff size=2>We use a trend file system it outputs a single line to a text file e.g. final test trend.</FONT></SPAN></DIV><DIV><SPAN class=172135614-17082004><FONT face=Arial color=#0000ff size=2>Put in the serial number date of test time of test test rack no test rack position operator id duration of test test result pass/fail software version and any #comment.#</FONT></SPAN></DIV><DIV><SPAN class=172135614-17082004><FONT face=Arial color=#0000ff size=2>The title of the file is updated by month change e.g. final_test_trend_8_2004.txt</FONT></SPAN></DIV><DIV><SPAN class=172135614-17082004><FONT face=Arial color=#0000ff size=2>Then you just open the trend file and check the units that have run.</FONT></SPAN></DIV><DIV><SPAN class=172135614-17082004><FONT face=Arial color=#0000ff size=2>Make sure that you comma delimit them then you can read them into excel etc.</FONT></SPAN></DIV><DIV><SPAN class=172135614-17082004><FONT face=Arial color=#0000ff size=2>Depending on throughput it doesn't need to get big, and it has been very reliable.</FONT></SPAN></DIV><DIV><SPAN class=172135614-17082004><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV><DIV><SPAN class=172135614-17082004><FONT face=Arial color=#0000ff size=2>Regards Mike</FONT></SPAN></DIV><BLOCKQUOTE>  <DIV class=OutlookMessageHeader dir=ltr align=left><FONT face=Tahoma   size=2>-----Original Message-----<BR><B>From:</B> Ross Bledsoe   [mailto:RBLEDSOE@Coinco.com]<BR><B>Sent:</B> 17 August 2004   14:30<BR><B>To:</B> VRF<BR><B>Subject:</B> [vrf] Directory sort by   time<BR><BR></FONT></DIV>  <P><FONT face=Arial>Good  morning,</FONT> <BR><FONT face=Arial>My VEE   application writes the serial number of passed units to a directory on the   network.  I would like to write another application or function to read   the directory of passed units and count how many units have passed each   hour.  I have hacked the dir4.vee program that was posted 10-2-03 and I   believe I can accomplish what I want to do using some of the objects from this   code.  What I'm wondering is if there is an easier way using WIN API   calls or an Active X solution?   Any thoughts would be   appreciated.</FONT></P>  <P><FONT face=Arial>Ross</FONT> </P>---<BR>You are currently subscribed to vrf   as: MStrutt@tycoelectronics.com<BR>To subscribe send a blank email to   "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to   "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list,   email "vrf@agilent.com". <BR>If you need help with the mailing list send a   message to "owner-vrf@it.lists.it.agilent.com". </BLOCKQUOTE>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list,  email "vrf@agilent.com".  <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></HTML>
