> I tried searching the VEE archive,
> but got too many results to make sense of.
Dave tells me it will be here shortly.
As a general tip, one way to get around that is to select results with
attachments. My search was
BodyContains = union
HasAttachment = yes
Unfortunately you can't do that from the web page because I don't know how
to eliminate field data if none is required. IOW, If I put HasAttachment on
the page then it would always be either Yes or No, never DontCare.
-SHAWN-
HasAttachment = yes
-SHAWN-
