vrf Installing VeeRuntime
Question asked by VRFuser on Aug 20, 2004
<DIV>Thanks a lot all. If I installed the correct version of Internet explorer everything is solved.</DIV><DIV>But now I have come up with a new problem. To work with Vee Pro I need the correct I/O libraries so I installed the version M.01.01.04. When rebooting my sytem the event viewer tells me: "The wn1394 service failed to start due to the following error: <BR>The system cannot find the file specified." and </DIV><DIV>"The description for Event ID ( 24 ) in Source ( SiclHwcheck ) could not be found. It contains the following insertion string(s): , atapi, DeviceScsiPort0.Translated." </DIV><DIV>Installing patch 3 and 2 did not solve this error.</DIV><DIV>If I remove parts of the installation so that only SICL is installed I only get the first error.</DIV><DIV>What am I doing wrong? I already have this on 2 Windows NT 4 sytems.</DIV><DIV> </DIV><DIV>Lots of thanks</DIV><DIV> </DIV><DIV>Yoeri  <BR><BR><B><I>"Pickles, Warren" |Warren.Pickles@tycoelectronics.com></I></B> wrote:</DIV><BLOCKQUOTE class=replbq style="PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #1010ff 2px solid"><META content="MSHTML 6.00.2800.1458" name=GENERATOR><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004>Yoeri,</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004>It might be that your PC doesn't meet the system requirements.</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004>I got something like this but not quite the same.  The installation got into an endless loop (seemingly) while installing Microsoft .Net Framework.  It turned out to be because the PC did not have a recent enough Internet Explorer version.  It has to have 5.01 or later; my PC only had v4.  Installing IE of correct version fixed the problem.  Also I note you have NT4 sp6 ... apparently NT4 sp6a is required.</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004>From the help file:</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004></SPAN></FONT> </DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004>The minimum system requirements for VEE Pro RunTime are:</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004> .NET Framework</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004> PC with a Pentium 120 MHz processor (266 MHz Pentium II or higher recommended)</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004> Windows 98SE, WindowsME, Windows NT 4.0(SP6a), Windows 2000(SP4), or Windows XP(SP1) operating system</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004> 24 MB RAM with Windows 98, 48 MB RAM with Windows NT/Windows 2000</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004> Hard disk free space: 70 MB minimum (105 MB with MATLAB and tutorials)</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004> CD-ROM drive</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004> 15-inch monitor 800x600 Super VGA (17-inch 1024x768 Ultra VGA or larger recommended)</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004> PC keyboard</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004> 2-button mouse (3rd button, if present, is not used)</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004> Desired instruments, interface cards, and other peripherals as needed<BR></SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004>Also you have to have IO libs M.01.01.04 if you want do instrument IO.</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004></SPAN></FONT> </DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004>Hope this helps,</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004>Warren</SPAN></FONT></DIV><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004> </DIV></SPAN></FONT><DIV><FONT face=Arial color=#0000ff size=2><SPAN class=890221808-19082004> </DIV></SPAN></FONT><BLOCKQUOTE><DIV class=OutlookMessageHeader dir=ltr align=left><FONT face=Tahoma size=2>-----Original Message-----<BR><B>From:</B> Yoeri Arien [mailto:yoeri_arien@yahoo.co.uk]<BR><B>Sent:</B> 19 August 2004 09:00<BR><B>To:</B> VRF<BR><B>Subject:</B> [vrf] Installing VeeRuntime<BR><BR></FONT></DIV><DIV>Hello </DIV><DIV> </DIV><DIV>I want to install the runtime engine on the computers of the operator and I always get "1603: Error installing Microsoft .Net Framework". This happens when the setup is unpacking the data, just before the installation. Then the installation is automaticcaly stopped.</DIV><DIV>I am trying to install the software on Windows NT 4.0 sp6 workstations.</DIV><DIV>What can I do to solve this?</DIV><DIV> </DIV><DIV> </DIV><DIV>greetings</DIV><DIV> </DIV><DIV> </DIV><DIV>Yoeri</DIV><P><HR SIZE=1><FONT face="Verdana, Arial, Helvetica, sans-serif" size=2><A href="http://uk.rd.yahoo.com/evt=21626/*http://uk.messenger.yahoo.com"><STRONG><FONT face="Arial, Helvetica, sans-serif">ALL-NEW Yahoo! Messenger</FONT></STRONG></A><FONT face="Arial, Helvetica, sans-serif"><STRONG> - all new features - even more fun!</STRONG></FONT><STRONG><FONT color=#ff9900> </FONT></STRONG></FONT>--- You are currently subscribed to vrf as: Warren.Pickles@tycoelectronics.com To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BLOCKQUOTE>---<BR>You are currently subscribed to vrf as: yoeri_arien@yahoo.co.uk<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". </BLOCKQUOTE><p>          <hr size=1> <font size="2" face="Verdana, Arial, Helvetica, sans-serif"><a href="http://uk.rd.yahoo.com/evt=21626/*http://uk.messenger.yahoo.com"><strong><font face="Arial, Helvetica, sans-serif">ALL-NEW Yahoo! Messenger</font></strong></a><font face="Arial, Helvetica, sans-serif"><strong> - all new features - even more fun!</strong></font><strong><font color="#FF9900"> </font></strong></font> ---You are currently subscribed to vrf as: rsb@soco.agilent.comTo subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list,  email "vrf@agilent.com".If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
