Hi Russ
the snapshots you sent only show a loop termination if
you hit the "cancel" button.
"The problem is after correcting the mistake and going into the retry loop,
it stays in the loop even though it's showing that
the measurements are now passing."
Do you have a "break" somewhere that you didn't show us?
Stan
PS- I'd suggest sending actual code snippet rather than screendumps-
will make it easier for folks to help
Stan
> Too much modifying..
If you want to send me the macro I'll give it a try.
-SHAWN-
