I am supposing tat you have one 81110 pulse generator and
one 54542C oscilloscope.
Because the panel driver (for the 54542C oscilloscope) is rather slow,
I recommend you to use Direct I/O for the applications that need speed.
In this case, you can use the panel driver to setup the scope and
use Direct I/O to acquire and transfer waveform data. Binary data
transfer may accelerate the speed.
Use SRQ of the scope for the synchronization (to know the end of
the waveform acquisition.)
FUKUI Yutaka
wenhan@itri.org.tw wrote:
> I am currently using VEE 5.0. version, I want to control the pulse
> generator 81110 (plug & play driver) and oscilloscope 54542C (panel
> driver). There are 2 problems.
> I use the pulse generator to input 2 different pulses, and I want to
> download the screen of the oscilloscope for post-processing. When I place 2
> oscilloscope icons in series with 2 pulse gen
> icons(pulse1-oscilloscope1-pulse2-oscilloscope2) for downloading the
> screen, an error occurs. I don't know how to exclude the error.
> It seems that the oscilloscope cannot catch up the switching speed of the
> pulse generator, not every generated pulse can be displayed on the screen
> of the oscilloscope. Is there any method to improve the situation?
> Thanks.
> You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com
> If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
* $BJ!0f!!K-!J (BFUKUI Yutaka)
* E-Mail: fukui.yutaka@jp.fujitsu.com
* $BIY;NDL3t<02q<R!!@n:j9)>l (B
* $B$b$N$E$/$j?d?JKIt!&@8;:5;=Q3+H/E}3gIt!!;n835;=Q (BPj <-- 2004/10/01 $B$h$j (B
$B?&@)$,JQ$j$^$7$? (B
* $B7WB,@_Hw3+H/It (BHomePage http://www.psl.fujitsu.co.jp/htd2/ksk/
* $B@n:j;TCf866h>e>.EDCf#4 (B- $B#1 (B- $B#1!!M9JXHV9f!' (B211-8588
* TEL $B!!30@~ (B 044-754-3661, $B!!Fb@~ (B 711-3-1966,7 <-- 2004/09/27 $B$h$j30@~$,JQ (B
$B$j$^$7$? (B
* FAX $B!!30@~ (B 044-754-3509, $B!!Fb@~ (B 711-3-5359
FUKUI Yutaka
> Thanks.
$B$j$^$7$? (B
Thanks.
