<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1"><META content="MSHTML 5.00.3819.300" name=GENERATOR></HEAD><BODY><DIV><FONT color=#0000ff size=2><SPAN class=661414208-19082004>And you have to be the admin for sure.....</SPAN></FONT></DIV><DIV><FONT color=#0000ff size=2><SPAN class=661414208-19082004></SPAN></FONT> </DIV><DIV><FONT color=#0000ff size=2><SPAN class=661414208-19082004></SPAN></FONT> </DIV><DIV><FONT color=#0000ff size=2><SPAN class=661414208-19082004></SPAN></FONT> </DIV><DIV><FONT color=#0000ff size=2><SPAN class=661414208-19082004>From Microsoft Web PAge:</SPAN></FONT></DIV><DIV><FONT color=#0000ff size=2><SPAN class=661414208-19082004></SPAN></FONT> </DIV><DIV><FONT color=#0000ff size=2><SPAN class=661414208-19082004></SPAN></FONT> </DIV><DIV><FONT color=#0000ff size=2><SPAN class=661414208-19082004><H2>.NET Framework 1.1 Redistributable</H2><P>To run applications on the .NET Framework, you need:</P><TABLE border=1 borderColorDark=#999999 borderColorLight=#ffffff cellPadding=5 cellSpacing=0 class=tblMatrix frame=below width="100%"> <TBODY> <TR> <TD class=tblHeader colSpan=2 vAlign=top>Minimum Requirements</TD></TR> <TR> <TD class=tblColOne vAlign=top>Processor </TD> <TD class=tblData vAlign=top> <UL> <LI>Client (a computer not working in a server capacity): 90-megahertz (MHz) Intel Pentium-class processor <LI>Server (a computer working in a server capacity): 133-MHz Intel Pentium-class processor </LI></UL></TD></TR> <TR> <TD class=tblColOne vAlign=top>Operating System</TD> <TD class=tblData vAlign=top>The .NET Framework 1.1 Redistributable is supported on the following platforms:<BR> <UL> <LI>Microsoft Windows Server 2003* (.NET Framework 1.1 is installed as part of the operating system) <LI>Windows XP Professional* <LI>Windows XP Home Edition <LI>Windows 2000* <LI>Windows Millennium Edition (Windows Me) <LI>Windows 98 <LI>Microsoft Windows NT 4.0 Service Pack 6a </LI></UL><B>Notes:</B> ASP.NET Web applications and XML Web services can only be hosted on Windows XP Professional, Windows 2000, and Windows Server 2003<BR><BR>The .NET Framework 1.1 Redistributable cannot be installed on 64-bit computers; Windows NT 4.0 Terminal Server is not supported </TD></TR> <TR> <TD class=tblColOne vAlign=top>Memory</TD> <TD class=tblData vAlign=top> <UL> <LI>Client: 32 megabytes (MB) of RAM, 96 MB recommended <LI>Server: 128 MB of RAM, 256 MB recommended </LI></UL></TD></TR> <TR> <TD class=tblColOne vAlign=top>Hard Disk</TD> <TD class=tblData vAlign=top>110 MB of hard disk space required, 40 MB additional hard disk space required for installation (150 MB total) </TD></TR> <TR> <TD class=tblColOne vAlign=top>Display</TD> <TD class=tblData vAlign=top>800 x 600 or higher-resolution display with 256 colors </TD></TR> <TR> <TD class=tblColOne vAlign=top>Input Device</TD> <TD class=tblData vAlign=top>Microsoft mouse or compatible pointing device </TD></TR> <TR> <TD class=tblColOne vAlign=top>Other</TD> <TD class=tblData vAlign=top> <UL> <LI>Microsoft Internet Explorer 5.01 or later is required (click to get <A href="http://www.microsoft.com/windows/ie/default.asp">Internet Explorer 6.0</A>). <LI>Microsoft Data Access Components 2.6 is required for data scenarios (<A href="http://www.microsoft.com/downloads/details.aspx?FamilyID=6c050fe3-c795-4b7d-b037-185d0506396c&displaylang=en">Microsoft Data Access Components 2.8</A> is recommended on a server). <LI><A href="http://www.microsoft.com/windows/directx/default.aspx">Microsoft DirectX 9b</A> is required to execute managed DirectX applications <LI>Install the latest Windows service packs and critical updates from the <A href="http://www.windowsupdate.com/">Windows Update site</A>. <LI>Installation of the .NET Framework 1.1 is split into two parts: the core and language packs. The core contains everything you need to run .NET Framework applications; all dialog boxes and error messages will be in English. If you want dialog boxes and error messages in another language, you must also install the corresponding language pack. For more information, see the <A href="http://msdn.microsoft.com/library/default.asp?url=/downloads/list/netdevframework.asp">.NET Framework Downloads</A> page. </LI></UL></TD></TR></TBODY></TABLE></SPAN></FONT></DIV><DIV><FONT color=#0000ff size=2><SPAN class=661414208-19082004></SPAN></FONT> </DIV><DIV><FONT color=#0000ff size=2><SPAN class=661414208-19082004></SPAN></FONT> </DIV><DIV><FONT color=#0000ff size=2><SPAN class=661414208-19082004></SPAN></FONT> </DIV><DIV><FONT color=#0000ff size=2><SPAN class=661414208-19082004></SPAN></FONT> </DIV><DIV><FONT color=#0000ff size=2><SPAN class=661414208-19082004></SPAN></FONT> </DIV><DIV><FONT color=#0000ff size=2><SPAN class=661414208-19082004></SPAN></FONT> </DIV><DIV><FONT color=#0000ff size=2><SPAN class=661414208-19082004></SPAN></FONT> </DIV><DIV><FONT color=#0000ff size=2><SPAN class=661414208-19082004></SPAN></FONT> </DIV><BLOCKQUOTE> <DIV align=left class=OutlookMessageHeader dir=ltr><FONT face=Tahoma size=2> <TABLE border=1 borderColorDark=#999999 borderColorLight=#ffffff cellPadding=5 cellSpacing=0 class=tblMatrix frame=below width="100%"> <TBODY> <TR> <TD class=tblColOne vAlign=top>Operating System</TD> <TD class=tblData vAlign=top>The .NET Framework 1.1 SDK can be installed on the following platforms:<BR> <UL> <LI>Microsoft Windows Server 2003 family <LI>Windows 2000, with the latest Windows service pack and critical updates available from the <A href="http://www.microsoft.com/security/">Microsoft Security Web site</A> <LI>Windows XP (Windows XP Professional is required to run ASP.NET) </LI></UL><B>Note:</B> The .NET Framework SDK 1.1 cannot be installed on 64-bit computers; Windows Millennium Edition and Microsoft Windows NT 4.0 are not supported </TD></TR></TBODY></TABLE>-----Ursprngliche Nachricht-----<BR><B>Von:</B> Pickles, Warren [mailto:Warren.Pickles@tycoelectronics.com]<BR><B>Gesendet:</B> 19 August 2004 10:26<BR><B>An:</B> VRF<BR><B>Betreff:</B> [vrf] RE: Installing VeeRuntime<BR><BR></DIV></FONT> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004>Yoeri,</SPAN></FONT></DIV> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004>It might be that your PC doesn't meet the system requirements.</SPAN></FONT></DIV> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004>I got something like this but not quite the same. The installation got into an endless loop (seemingly) while installing Microsoft .Net Framework. It turned out to be because the PC did not have a recent enough Internet Explorer version. It has to have 5.01 or later; my PC only had v4. Installing IE of correct version fixed the problem. Also I note you have NT4 sp6 ... apparently NT4 sp6a is required.</SPAN></FONT></DIV> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004>From the help file:</SPAN></FONT></DIV> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004></SPAN></FONT> </DIV> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004>The minimum system requirements for VEE Pro RunTime are:</SPAN></FONT></DIV> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004> .NET Framework</SPAN></FONT></DIV> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004> PC with a Pentium 120 MHz processor (266 MHz Pentium II or higher recommended)</SPAN></FONT></DIV> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004> Windows 98SE, WindowsME, Windows NT 4.0(SP6a), Windows 2000(SP4), or Windows XP(SP1) operating system</SPAN></FONT></DIV> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004> 24 MB RAM with Windows 98, 48 MB RAM with Windows NT/Windows 2000</SPAN></FONT></DIV> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004> Hard disk free space: 70 MB minimum (105 MB with MATLAB and tutorials)</SPAN></FONT></DIV> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004> CD-ROM drive</SPAN></FONT></DIV> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004> 15-inch monitor 800x600 Super VGA (17-inch 1024x768 Ultra VGA or larger recommended)</SPAN></FONT></DIV> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004> PC keyboard</SPAN></FONT></DIV> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004> 2-button mouse (3rd button, if present, is not used)</SPAN></FONT></DIV> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004> Desired instruments, interface cards, and other peripherals as needed<BR></SPAN></FONT></DIV> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004>Also you have to have IO libs M.01.01.04 if you want do instrument IO.</SPAN></FONT></DIV> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004></SPAN></FONT> </DIV> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004>Hope this helps,</SPAN></FONT></DIV> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004>Warren</SPAN></FONT></DIV> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004> </DIV></SPAN></FONT> <DIV><FONT color=#0000ff face=Arial size=2><SPAN class=890221808-19082004> </DIV></SPAN></FONT> <BLOCKQUOTE> <DIV align=left class=OutlookMessageHeader dir=ltr><FONT face=Tahoma size=2>-----Original Message-----<BR><B>From:</B> Yoeri Arien [mailto:yoeri_arien@yahoo.co.uk]<BR><B>Sent:</B> 19 August 2004 09:00<BR><B>To:</B> VRF<BR><B>Subject:</B> [vrf] Installing VeeRuntime<BR><BR></FONT></DIV> <DIV>Hello </DIV> <DIV> </DIV> <DIV>I want to install the runtime engine on the computers of the operator and I always get "1603: Error installing Microsoft .Net Framework". This happens when the setup is unpacking the data, just before the installation. Then the installation is automaticcaly stopped.</DIV> <DIV>I am trying to install the software on Windows NT 4.0 sp6 workstations.</DIV> <DIV>What can I do to solve this?</DIV> <DIV> </DIV> <DIV> </DIV> <DIV>greetings</DIV> <DIV> </DIV> <DIV> </DIV> <DIV>Yoeri</DIV> <P> <HR SIZE=1> <FONT face="Verdana, Arial, Helvetica, sans-serif" size=2><A href="http://uk.rd.yahoo.com/evt=21626/*http://uk.messenger.yahoo.com"><STRONG><FONT face="Arial, Helvetica, sans-serif">ALL-NEW Yahoo! Messenger</FONT></STRONG></A><FONT face="Arial, Helvetica, sans-serif"><STRONG> - all new features - even more fun!</STRONG></FONT><STRONG><FONT color=#ff9900> </FONT></STRONG></FONT>--- You are currently subscribed to vrf as: Warren.Pickles@tycoelectronics.com To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BLOCKQUOTE>---<BR>You are currently subscribed to vrf as: Detlef.Baranski@PILKINGTON.de<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". </BLOCKQUOTE>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></HTML><P><FONT SIZE=2 FACE="Arial">This message and any attachments are confidential, for the exclusive use of the addressee and may be legally privileged. Any other distribution, use or reproduction is unauthorised and prohibited. If you have received this message in error, please notify the sender immediately and delete the message from your system. </FONT></P><BR><P><FONT SIZE=2 FACE="Arial">Visit our internet site at http://www.pilkington.com</FONT></P>
