Joel,
>From what little I know about VEE, my interpretation of VEE panel
behavior:
1. Generally, the focus is on the first object in the panel.
(object order determined left -> right and top -> bottom)
2. When present, data input objects like Constants, Sliders, Toggles,
Selection, etc., have priority over "OK" object and will get the focus
irrespective of their position relative to the OK object(s).
I am not into VEE7 yet, but as Mike pointed out you could probably
define the order in VEE7.
-Vinod
--- "DUNSMORE,JOEL (A-Sonoma,ex1)" <joel_dunsmore@agilent.com> wrote:
> Hello Vinod,
> Great Solution!
> I've just one "funny" which I don't understand. I was using toggle
> controls, which I changed to (OK) buttons. (I also have some other
> check boxes). When I change the tab order, the tabbing works fine.
> But the first time the panel comes up, the other check boxes have the
> focus. Any idea why this would not respond to the set tab orders. I
> worked around this by adding 4 tabs at the beginning...but odd. I've
> attached the modified program so you can see it too. Delete the 4
> tabs to see the original behavior.
> Joel
> -----Original Message-----
> From: Vinod [mailto:papineni_vinod@yahoo.com]
> Sent: Thursday, August 12, 2004 11:29 PM
> To: VRF
> Subject: [vrf] Re: Setting Properties (color) of buttons, changing
> tab
> order
> Sorry, here is the attachment...
> --- Vinod <papineni_vinod@yahoo.com> wrote:
> > Joel,
> > The attached example changes the tab order but not the colors. You
> > could modify this with the concept from Mike Grove's example to
> > change
> > color.
> > -Vinod
> wrote:
> > > Hi Guys,
> > > I have a User Object in a program with 4 buttons: "Meas
> Open",
> > > "Meas Short", "OK", "Cancel". They're all in one big "repeat
> until
> > > break", with the OK going to the break, the cancel going to stop,
> > and
> > > the other two doing useful things. (They're all in a repeat so
> that
> > > the open can be repeatedly measured without starting over).
> > > This Object pops its panel view when activiated. The tab order
> is
> > > Meas Open first. What I'd like to do is change the focus the
> "OK"
> > > key after either meas key has been pressed, and change the color
> of
> > > the OK key to green. I can go into the button and change it
> > > permanently, but how to do it programatically?. Also the tab
> > order,
> > > can I change the object tab order (or just as good, "fake a tab")
> > to
> > > get the focus on OK, after the first measurement?
> > > Thanks, Joel
__________________________________
Do you Yahoo!?
New and Improved Yahoo! Mail - 100MB free storage!
http://promotions.yahoo.com/new_mail
behavior:
-Vinod
> Hello Vinod,
> Great Solution!
> Joel
> To: VRF
> tab
> order
> > Joel,
> > change
> > color.
> > -Vinod
> wrote:
> > > Hi Guys,
> Open",
> until
> > and
> that
> is
> "OK"
> of
> > order,
> > to
> > > Thanks, Joel
Do you Yahoo!?
> 2) Place pieces of the MATLAB manual in your ears to block the
complaints.
Standard practice in our office
could modify this with the concept from Mike Grove's example to change
color.
-Vinod
> Hi Guys,
> I have a User Object in a program with 4 buttons: "Meas Open",
> "Meas Short", "OK", "Cancel". They're all in one big "repeat until
> break", with the OK going to the break, the cancel going to stop, and
> the other two doing useful things. (They're all in a repeat so that
> This Object pops its panel view when activiated. The tab order is
> Meas Open first. What I'd like to do is change the focus the "OK"
> key after either meas key has been pressed, and change the color of
> permanently, but how to do it programatically?. Also the tab order,
> can I change the object tab order (or just as good, "fake a tab") to
> Thanks, Joel
> You are currently subscribed to vrf as: papineni_vinod@yahoo.com
Do you Yahoo!?
Express yourself with Y! Messenger! Free. Download now.
http://messenger.yahoo.com
color.
-Vinod
> Hi Guys,
> Thanks, Joel
Do you Yahoo!?
