hi,
thanks for your help. i can display the fft frequency now. but i still
have a question. it's that when i use the build waveform object, the time
must be 10 times of the main sweep time. i don't know why it works in this
way? by the way, how to set the sample rate by computer? thanks a lot.
_________________________________________________________________
ĵʼϵͳ MSN Hotmail http://www.hotmail.com
i am using the VEE to do signal processing. after the fft, i want to
diplay it. usually the datas are in array, but every element is complex.
how to display the frequecy and how to scale the diaplay?
any reply is welcome. thanks a lot.
MSN Explorer: http://explorer.msn.com/lccn
