<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><META http-equiv=Content-Type content="text/html; charset=iso-8859-1"><META content="MSHTML 6.00.2800.1264" name=GENERATOR><STYLE></STYLE></HEAD><BODY bgColor=#ffffff><DIV><FONT face=Arial size=2>Hi vrf,</FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2>we have a problem to build x,y,z Coordinates. In detail we have values in a container (size 400) and these values are the z-components in the form z1,z2, z3, z4,..... But</FONT><FONT face=Arial size=2> we want to build 400 (x,y,z) coordinates in the format (1,1,z1), (1,2,z2), (1,3,z3).....(1,20,z20), (2,1,z21), (2,2,z22),........(20,20,z400). </FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2>Example: </FONT></DIV><DIV><FONT face=Arial size=2>container with size 400: 100,10,30....36 should be changed to coordinates in the form </FONT><FONT face=Arial size=2>(1,1,100), (1,2,10), (1,3,30)........(20,20,36).</FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2>What would be a way for a solution?</FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2>What can we further do to delete the first 10 fields of a container (size 410 to size 400) or only read every second element of a container (formular?)</FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2>Best greetings</FONT></DIV><DIV><FONT face=Arial size=2>martin hauder</FONT></DIV><DIV><FONT face=Arial size=2>------------------------------------------------------------------<BR>mdh technology GmbH<BR>Dr. Martin Hauder<BR>Eberspoint, Fliederstr. 11<BR>84149 Velden, Germany<BR> <BR>Tel.: +49 (0)8742/967138<BR>Fax: +49 (0)8742/967138<BR> <BR>Lieferanschrift:<BR>(Niederlassung Ebersberg)<BR>mdh technology GmbH<BR>Reith 1a<BR>85560 Ebersberg, Germany<BR>Tel: 08092/868523<BR>Fax: 08092/868523<BR> </FONT></DIV><DIV> </DIV><DIV><FONT face=Arial size=2>Mobil: 0160/91981875<BR>E-mail: <A href="mailto:hauder@mdh-technology.de">hauder@mdh-technology.de</A> <BR><A href="http://www.mdh-technology.de">http://www.mdh-technology.de</A></FONT></DIV>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></HTML>
What's the container? If these are strings, you could use From String TOKEN
EXCLUDEing "," and ".". Analyze the resulting array, replace what you want
and reassemble it into a string again.
-SHAWN-
