Calc the RMS value.
From: David Bielawski [mailto:David.Bielawski@raymarine.com]
Sent: Wednesday, August 25, 2004 5:53 AM
To: VRF
Subject: [vrf] Reading chopped current on an HP6654
Hi All.
Using an HP6654 power supply I was able to measure the current drawn by a
board directly from the supply.
However, the design of the board has changed and the current drawn is
"chopped" in to blocks at a frequency of 200Hz. [i.e max ON time 5ms] I have
tried various ways of obtaining the current measurement and although I am
aware that there are fairly straightforward hardware ways of overcoming this
issue, I prefer to use the software route.
Anybody had a similar experience and can shed some light on this?
Best regards
Dave Bielawski
Test Development Engineer
Raymarine
...world leaders in marine electronics
Tel : 44 (0)23 9269 3611 (1043) Fax : 44 (0)23 9269 4642 e-mail :
david.bielawski@raymarine.com www.raymarine.com The information in this
e-mail is confidential and is intended solely for the addressee. Access,
copying or re-use of information contained in it by anyone else is
unauthorised
You are currently subscribed to vrf as: rwarren@amti.net To subscribe send a
blank email to "join-vrf@it.lists.it.agilent.com".
To: VRF
Hi All.
Best regards
Dave Bielawski
Raymarine
unauthorised
Using an HP6654 power supply I was able to measure the current drawn by a board directly from the supply.
However, the design of the board has changed and the current drawn is "chopped" in to blocks at a frequency of 200Hz. [i.e max ON time 5ms]
I have tried various ways of obtaining the current measurement and although I am aware that there are fairly straightforward hardware ways of overcoming this issue, I prefer to use the software route.
Best regards
Dave Bielawski
Raymarine
e-mail : david.bielawski@raymarine.com www.raymarine.com
The information in this e-mail is confidential and is intended solely for the addressee. Access, copying or re-use of information contained in it by anyone else is unauthorised
