This is an additional information.
To String Properties -> Data Format
Set array-separator of the To String Properties to "".
FUKUI Yutaka
Stan Bischof wrote:
> > Hi
> > Does anyone have a non loop way to convert a text array to string
> If you mean concatenate all the array elements (strings) into
> a single string- sure- the To String object will do that just fine
> if you turn off the EOL
> Stan
> You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com
> If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
* $BJ!0f!!K-!J (BFUKUI Yutaka)
* E-Mail: fukui.yutaka@jp.fujitsu.com
* $BIY;NDL3t<02q<R!!@n:j9)>l (B
* $B$b$N$E$/$j?d?JKIt!&@8;:5;=Q3+H/E}3gIt!K7WB,@_Hw3+H/It (B
* $B7WB,@_Hw3+H/It (BHomePage http://www.psl.fujitsu.co.jp/htd2/ksk/
* $B@n:j;TCf866h>e>.EDCf#4 (B- $B#1 (B- $B#1!!M9JXHV9f!' (B211-8588
* TEL $B!!30@~ (B 044-754-3657, $B!!Fb@~ (B 711-3-1966,7
* FAX $B!!30@~ (B 044-754-3509, $B!!Fb@~ (B 711-3-5359
FUKUI Yutaka
Stan Bischof wrote:
> > Hi
> Stan
You're welcome for the the examples that I shared, but I must point out
(again) that I didn't write them, I just pulled them out of my VRF archive
of usefull stuff. Due credit where credit is due! (I'm not sure who wrote
each piece of code - you know who you are!)
Reiner
