Could one not create a string of nulls using the Data|Allocate Array|Text.
Add an input terminal, init value, use a Constant|Text box (no entry) NULL
as input, and build any shape array filled with nulls. Thus pass this to
your DLL?
rufus
Sent: Thursday, August 19, 2004 2:03 PM
To: VRF
Subject: [vrf] Re: Importing DLL's, passing by reference
> Token Format with "
" as the excluded token.
Er, excluded character. Well, I'm sure you know what I meant
Thanks to Shaun Trussler "C Programming 101" is back on-line, and there's a
section there that tries to explain what's going on with char* and char**. I
don't know if it does so successfully or not, but it's below the Type Table
(the second paragraph below NOTE 2). There's a drawing right below it that
tries to represent what char** means. The Type Table is directly accessible
at:
www.oswegosw.com/vrf_archive/CProgramming101.htm#refTypeTable
All this stuff is backed up now too. I guess it only takes a moment's lapse
of concentration to let Front Page run amok.
I'm going back to working on the search stuff now. There may be happy news
about that before the day's over. It won't be completely finished, but it
will probably be back to some semblance of passing search data to the search
server & reporting parameters back to you.
-SHAWN-
You are currently subscribed to vrf as: rwarren@amti.net To subscribe send a
blank email to "join-vrf@it.lists.it.agilent.com".
your DLL?
rufus
To: VRF
> Token Format with "
at:
-SHAWN-
